4020 john deere
/ 4020 john deere #1
Rwelder
4020 John Deere tractor
I just bought a 4020 John Deere tractor and when you hook up shredder and lift it up it leaks back down on it's own I can lift again but it slowly goes back down need help please thanks. Rwelder
/ 4020 john deere #2
I would think that it was the main cylinder leaking by.
/ 4020 john deere #3
There is a lever on the right just under your right leg (down low) when setting in the seat. Try putting it into another position and see what happens? It is load and load depth control lever. Ken Sweet
/ 4020 john deere
I tried to adjust load but it doesn't seem to make any differance
/ 4020 john deere
Is there a main cylinder on this tractor if so where is it located?
/ 4020 john deere #6
It is internal to the housing under the seat and is mounted more or less horizontal. You will need to remove the seat and the top lid (housing) section. This isn't a light weight piece by the way, a chain hoist is what I recommend for this job.
/ 4020 john deere
Do all 4020 John deeres tractors have this internal cylinder you can tell I'm just a welder
/ 4020 john deere
Thanks I appreciate the info
/ 4020 john deere #10
Is the handle drifting down also and your just repositioning the handle ?
How are you "I can lift again" ?
/ 4020 john deere #11
There should be an inspection plug on the right side of the rockshaft housing. If you remove this, you should be able to see the open end of the rockshaft cylinder. With weight on the draft arms, any leakage should be evident.
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2009 International 4300 Digger Derrick (A62613)
2009 International...
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
