401 C hydraulic pump..??
/ 401 C hydraulic pump..?? #1
Fordcummins83
Albuquerque, Nm
Little bit of everything
Hey everyone! I have a JD 401c tractor, everything works great when it's cold, but the more it starts warming up the more it starts acting up and shuttering as if its sucking air, do you think this problem would be in my hydraulic pump? I was going to remove it but I want to check and make sure what you guys think first.. Any help would be greatly appreciated!!
/ 401 C hydraulic pump..?? #2
Several things can contribute to hyd problems on a tractor such as yours with a "closed-center" hyd system. Some diagnostics including pressure checks are in order before pump removal. Frt pump could be not getting sufficient oil supply from trans pump or possible high pressure internal leak depleting frt hyd output.
What should my pressures be and at what locations? Are there o-rings in the front pump that could have failed? The 3- point works fine all day long and the steering does too, just the loader shudders once it warms up
/ 401 C hydraulic pump..?? #4
If 3pt & steering work then I'd recommend checking stand-by pressure at the top of the hyd pump. PSI should be 2250-2350 psi. How long since hyd filters were changed and sump screen cleaned??
Probably been awhile, I really don't have the tools to be checking psi but is there a way I can check gpm or so on that?
/ 401 C hydraulic pump..?? #6
GPM can be checked with a flowrater. A 3000 psi gauge isn't very expensive about $30
/ 401 C hydraulic pump..?? #8
Remove parts key #7 and install gauge. Here's the spec's on parts key #7
Thread Size 0.562 IN
TPI (Threads Per Inch) 18
Thread Length 0.394 IN
Length 0.689 IN
Diameter 0.00 IN
Hex Size 0.688 IN
/ 401 C hydraulic pump..?? #9
Have you checked the charge pump?
Some photos may help.
Your pump is the same, except your charge pump is in your transmission housing (I believe)
Right Side
Left Side
TOP
BOTTOM
FRONT
BACK
/ 401 C hydraulic pump..?? #10
Length 0.689 IN
Diameter 0.00 IN
Hex Size 0.688 IN
The thread size per your specs will be SAE 6. Also called ORB (O Ring Boss)# 6. The 6 is for 6/16" or 3/8"
Hey guys, thanks alot for your help!! I really appreciate it, I just hooked my 3000psi gauge up to key 7, and i have no pressure there, even when i move the loader up and down, is this the correct port to check for pressure? or is there another one somewhere else where i can check pressure?
Thanks again!!
/ 401 C hydraulic pump..?? #12
Try checking pressure with hyd reverser in fwd & rev and trans in neutral.
Ok sure will, thanks again!! Also it hasn't ran in a few months so I tried everything again, and the loader and 3 point were shaking and the steering kept shaking also till it warmed up and it got a little better but still acted like it was short on pressure or had air in it
Great Dane Van Trailer (A63689)
Great Dane Van...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
Kenworth T6 (A63689)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Wacker Neuson HI400 Industrial Heater (A65579)
Wacker Neuson...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
