4 WD PROBLEMS
/ 4 WD PROBLEMS #1
Dr. Neil
kubota BX 1870
I have a Kubota BX 1870 and it has been great for over 6 years, but recently the 4 WD started knocking and jerking. I can't use it at all. Anyone have any ideas?
/ 4 WD PROBLEMS #2
Have you checked the drive shaft going from rear transmission to front axle? Possible u-joint is starting to fail.
/ 4 WD PROBLEMS
Thank you, I will check that tomorrow.
/ 4 WD PROBLEMS #4
I had similar problems on my bx25d, unsettling rhythmic noises, jerking, etc. Thanks to good advice on tbn, I detached and checked the u joints on the drive shaft, as suggested above. The front one was falling apart. The back one was fine. Apparently this is typical. Disassembly and replacement were easy. Found the parts diagram on Messick's. The parts arrived in a few days from them, for under $100. Reassembly took less than an hour. Anybody can do it!
2007 Jeep Wrangler SUV (A61574)
2007 Jeep Wrangler...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
