4 Series In The Field
   / 4 Series In The Field #11
We have been pulling a New Holland small square baler (a 273) with a belt kicker behind a Kubota L3830 for at least 10 years. It has been big enough to run it. When you are going downhill with a full haywagon you need to keep the speed down or it feels iffy, but we have never had issues with a lack of control.
Aaron Z
aczlan
Since you have a kicker i'm assuming you are also pulling your hay wagon while baling.
   / 4 Series In The Field #14
(My neighbor currently has all the equipment so no need to purchase)
I'd try to work a deal out with the neighbor to bale the 15 acres and save your money. Most people do it on shares or a fixed per bale cost. I was doing some googling last night about how much PTO HP it takes to run a square baler and came across this topic.
This post sums up why I wouldn't use anything besides a bigger machine pretty well:
It not only comes down to HP, it has a lot to do with weight of the tractor. It's recommended ( by NH) that your tractor at least equale the weight of your baler. Add a thrower, full wagon and a good hill..... Make sure your ropes is up and seat belt is on and get ready to have that baler and wagon hooked up in a much different configuration than you started. With that said, hills should be a big part of you future planing.
   / 4 Series In The Field #15
Looks like 4 horsepower is enough!
(...and that's without a pony motor)
Jump to 1:30:
   / 4 Series In The Field #16
I have a 4520 so basically the equivalent. I have used it for 5 years to mow rake and bale 15 acres. It works fine. HST is great for running a sickle mower and an older square baler. If the field is rough you'll have a rough ride, otherwise it's fine and has plenty of weight and horsepower. We have also used it quite a bit for loading logs onto a sawmill using a grapple. It will certainly do the work.
For last year I added 5085e and used it for the baler but I still cut with the 4520 because I like it better with the sickle. This year we have been offered my neighbors fields and will be baling 50 acres so I am now looking at disc mowers to increase efficiency. In dry grass though I can run the sickle at 6mph though. It gets too rough above that speed. The bigger tractor and disc mower will let me mow faster than that with the longer wheelbase, plus I can cut when its damp in the morning or evening.
   / 4 Series In The Field #17
I have a 4720 HST. It has rimguard in the rears and fronts are foam filled. 400cx loader. I've used it on a 9' haybine and square baler (not a kicker) with wagon. Worked well. Ran the same with a 4010 diesel ag tractor (84hp PTO). Prefer the 4720 due to HST and cab.
I use it for mowing (Woods BW12 and NH455 sickle), firewood tasks, hauling brush, snow removal, etc. The HST is very good for these tasks.
dsb
   / 4 Series In The Field #18
Have 4720 i run a new holland 311 baler with and have run many tractors on baler. 4720 with hydro is a dream with it. Set pto speed and go.
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Forklift (A59228)
Forklift (A59228)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
