4 in 1 bucket?
/ 4 in 1 bucket? #1
Roseaukaine
I've been wondering....what are the benefits to a 4-in-1 bucket over a standard bucket with a grapple? Can I still backblade and have a "useable" bucket with the 4 in 1? I would like to move around some small trees and brush from time to time, but not always.
I am considering the 300cx loader on a 3320 ehydro for this application. Would the 300cx handle the 4 in 1?
Thanks for any advise!!
/ 4 in 1 bucket? #2
I prefer a grapple or root grapple type attachment to the 4n1s I keep it on the tractor almost all the time.
I have a 4n1 on my loader and it just seems a little tedious. Whether pushing or trying to grab something - the grapple is much easier.
/ 4 in 1 bucket? #3
4in1s will backblade just like any other bucket, but they will also open up and backblade with the cutting edge on the top jaw. They will also doze when open. One of the handiest things they do, although many people do not have the hydraulics run to take advantage of it, is they will pick up piles (of debris, dirt, etc.) right to ground level leaving nothing to do by hand. When you haul firewood or large stuff, you can open the bucket 8-12" and make it bigger.
The grapple debate here is lengthy. The 4in1s will grab trees just as well as any grapple, but it will pale in comparison on brush. A bucket or root grapple would easily move brush 3x as fast if not faster...
/ 4 in 1 bucket?
Thanks....I was just wondering. I don't plan on moving any great amount of brush...just a few here and there, and nothing too large. My main concern is that the 3320 and 300cx loader wouldn't be powerful enough to operate the 4 in 1 at it's full potential.
/ 4 in 1 bucket? #5
Very well put, BJCSC. I have been experimenting with my 4n1 and I gotta
say that the fine grading capability with the 4n1 is better than w/ the BB. Of
course, the BB can rip, too. Grabbing rocks and logs for me would prob be
easier with a grapple bkt, but cleaning up piles is better with the 4n1, as you
say.
As for the JD3320, a 4n1 IS heavy but that tractor is a bit heavier than my
B21. Get a small 4n1 and it would work.
/ 4 in 1 bucket? #6
The 300cx will handle the 4in1 just fine. If you can fit it in the bucket it will lift it. The 61" bucket weighs just under 400 pounds I think...according to JD.
/ 4 in 1 bucket? #7
I think the biggest advatage of the 4 in 1 bucket that hasn't already been mentioned is that it's always there. You don't have to go install it or stop what you are doing to go get it, then after you are done, you don't have to take it off.
I really want one!!!!
Eddie
/ 4 in 1 bucket? #8
It takes some skill and experience to do this properly.
About 80% of the time I end up grabbing a big pile of air...
One other thing the 4-n-1 can do is to empty its load without lowering the bucket lip. I have used this ability a few times and it was a big time saver in the right situations.
I have borrowed tractors with a standard bucket and the 4-n-1 is much, much better at every task except carrying a bucket load of water.
/ 4 in 1 bucket? #9
I'm not sure of your method, but I'll describe it in case it may help: First, you have to be able to close the jaw and curl the bucket at the same time. If your 3rd function is diverted from your curl/dump it will be very difficult if not impossible. Approach your pile. Open the jaw almost all the way and dump the bucket until the dozer blade has it's cutting edge scraping the ground. The blade (back wall of the bucket) should be at or <45 deg angle from the ground, away from the tractor. Start to doze your pile. Once you have it all it front of the blade and collected, start to close your jaw. The jaw blade should contact the ground beyond the opposite side of the pile. If not, dump the bucket more so that it does. When the blade of your jaw contacts the ground, continue to close the jaw as you curl your bucket at a rate that keeps the jaw blade in contact with the ground. If you curl too fast you'll skip over some of your pile, too slow and the jaw will stop closing or dig. Once it's closed, if you've kept the jaw on the ground, everything will be in the bucket.
/ 4 in 1 bucket? #10
Thanks.
Right there is the problem. I would either close the jaw or curl the buck, not both at once, even though the machine is capable of that.
I will try that next week. (This week I am down in CA, getting my old house ready to sell. For some reason prices have stayed up in my area, and now is the time to get out.)
/ 4 in 1 bucket? #11
That's an excellent description, BJCSC. We were discussing this on
another recent thread. The downside of electric diverter hydraulics was
one point made.
I have been practicing this method and it certainly DOES take practice.
I watched a pro do it over and over with his 580 and it sure looked easy.
I am getting better, but my B21 is going up for sale very soon.
CURLY: Good point about dumping the load without using the curl
function. That would be an advantage when loading material into a dump
truck. (Good luck selling your house in Woodside.)
/ 4 in 1 bucket? #12
Dreamingreen,
I noticed in your sig that you have both the JD 61" bucket and the Frontier 4in1. Now that you have the 4in1, do you ever see the need for the "regular" bucket? Just wondering, because I'm about to order a tractor, and I'm considering only getting a 4in1, from all the good things I've read about them, and they seem to make a regular bucket obsolete.
/ 4 in 1 bucket? #13
Jason977 said:
Dreamingreen,
The dealer was'nt giving me what I thought was a decent price for the regular bucket on a trade to the 4in1 so I kept it. Definetly no "need" at all for the regular bucket. one observation I have made, the 4in1 is made out of thicker matierial and re-enforced much more than I thought it would be. I have used/abused it grubbing out partialy buried large rocks several times and it is standing up very well no bending or warping at all. I can't say enough about how handy and useful the 4in1 is grabbing large rocks, pulling small trees out by the roots. No need to get out and put a chain on something, just drive up clamp it and drive off.
/ 4 in 1 bucket? #14
...pulling small trees out by the roots...
I have gotten pretty good at this. Even though my bucket will only raise to 10', I have pulled trees up to about 15' high.
Open the bucket and raise it high. Drive up with the bucket in to the side of the tree and just a bit in front of it.
Using one brake and as sharp a turn as you can, you can almost make the tractor rotate around one rear wheel. This lets you push on the tree with the side of the bucket, where it will bend over and spring up between the parts of the open bucket.
Now lower it, moving back to keep the tree upright until you can close the bucket on it a foot or so above ground.
The only problem I have even found was breaking the tree off instead of grasping it with the bucket.
/ 4 in 1 bucket? #15
Sounds like tractor ballet, CURLY. If you post a video, a lot of us would like
to see it in action!
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
