4' brush hog on a TU155?
/ 4' brush hog on a TU155? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
4\' brush hog on a TU155?
Hi guys,
Do you think my TU155 would pull a 4' hog?
Fairly flat land, about 2.5 acres to keep under control.
I've been offered one and don't want to buy it if it isn't going to work ok. It has a slip clutch istalled on it already.
Cheers,
Chris.
Hi guys,
Cheers,
Chris.
/ 4' brush hog on a TU155? #3
Re: 4\' brush hog on a TU155?
I'm not real familiar with the TU155, but I assume that it's about the same power, size, etc. as my TX1500 (15 hp PTO).
I run a 4' rotary cutter behind my TX1500 and it does fine with it. When I get into weeds that are too tall (like 3 feet) I have to gear down, but it still cuts pretty well.
/ 4' brush hog on a TU155? #4
/ 4' brush hog on a TU155? #5
Again, I'm not too familiar with that particular model but a buddy has a TU180 and he pulls a 4 foot hog with no problems. Every now and again it belches black smoke when he gets into the 4'-5' stuff. Other than that he says it is no problem.
YMMV.
/ 4' brush hog on a TU155? #6
YMMV.
Iplayfarmer - great name!
Yes, the TU155 has the Mitsubishi K3C engine (900cc, 3cyl, 18.5 hp / 2700 rpm) and the sticker on the tractor says 15.5PS / 2500 rpm, which equates to about 15.2HP.
Do I need an overrun clutch?
Cheers,
Chris.
Cheers,
Chris.
/ 4' brush hog on a TU155? #9
I don't know if that model needs the over running clutch.
If you don't have it, consider weights on the front end. I have 4 x 45lbs on my TS1610. In some cases I think that is still not enough for my 4' bush hog. I may try more weight.
I don't know the weight of a TU155. But I expect it is similar to the older TS1610.
/ 4' brush hog on a TU155? #10
/ 4' brush hog on a TU155? #11
Yes, you need an overrunning clutch. It is not a live PTO.
Buck
/ 4' brush hog on a TU155? #12
Buck
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 CATERPILLAR 345CL EXCAVATOR (A60429)
2005 CATERPILLAR...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2016 Chevrolet...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2007 Land Rover Range Rover Sport (A59231)
2007 Land Rover...
2016 CATERPILLAR 349FL EXCAVATOR (A60429)
2016 CATERPILLAR...
