3rd valve hose size
/ 3rd valve hose size #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
What size hoses should I be running up to the front of the loader?
I will be operating a Power angle snow plow and a grapple bucket
The snow plow has 1/4" hoses while the grapple has about 1/2"
/ 3rd valve hose size #2
Grapples and plows have small cylinders, and are not continuously flowing, 1/4" hose is perfect for either. Some use 3/8" and that's fine too. Using 1/2" is a waste of $$$, real estate, and its much harder to work with.
/ 3rd valve hose size #3
I will partially agree with Kenny, 1/4" line is all you need. Depending on how you plan on running the hose, I typically recommend 3/8" hose simply because it is much tougher than the 1/4". But if nothing is able to get snagged, 1/4" is easier, cleaner and less money. :thumbsup:
I will probably go with 1/4" from the plow cylinders to the cushion valve and run 3/8" from the cushion valve back to the rear outlet till i have tim to do my 3rd valve
1993 EAST 102" X 48' SPREAD AXLE FLATBED TRAILER (A64276)
1993 EAST 102" X...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
1999 Freightliner FL80 Altec A75 75ft. Bucket Truck (A61573)
1999 Freightliner...
