3rd valve hose size
/ 3rd valve hose size #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
What size hoses should I be running up to the front of the loader?
I will be operating a Power angle snow plow and a grapple bucket
The snow plow has 1/4" hoses while the grapple has about 1/2"
/ 3rd valve hose size #2
Grapples and plows have small cylinders, and are not continuously flowing, 1/4" hose is perfect for either. Some use 3/8" and that's fine too. Using 1/2" is a waste of $$$, real estate, and its much harder to work with.
/ 3rd valve hose size #3
I will partially agree with Kenny, 1/4" line is all you need. Depending on how you plan on running the hose, I typically recommend 3/8" hose simply because it is much tougher than the 1/4". But if nothing is able to get snagged, 1/4" is easier, cleaner and less money. :thumbsup:
I will probably go with 1/4" from the plow cylinders to the cushion valve and run 3/8" from the cushion valve back to the rear outlet till i have tim to do my 3rd valve
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
17395SFL (A61568)
17395SFL (A61568)
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
