3rd valve hose size
/ 3rd valve hose size #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
What size hoses should I be running up to the front of the loader?
I will be operating a Power angle snow plow and a grapple bucket
The snow plow has 1/4" hoses while the grapple has about 1/2"
/ 3rd valve hose size #2
Grapples and plows have small cylinders, and are not continuously flowing, 1/4" hose is perfect for either. Some use 3/8" and that's fine too. Using 1/2" is a waste of $$$, real estate, and its much harder to work with.
/ 3rd valve hose size #3
I will partially agree with Kenny, 1/4" line is all you need. Depending on how you plan on running the hose, I typically recommend 3/8" hose simply because it is much tougher than the 1/4". But if nothing is able to get snagged, 1/4" is easier, cleaner and less money. :thumbsup:
I will probably go with 1/4" from the plow cylinders to the cushion valve and run 3/8" from the cushion valve back to the rear outlet till i have tim to do my 3rd valve
(2) 10 LUG WHEELS (A64281)
(2) 10 LUG WHEELS...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
(2) Lights (A64119)
(2) Lights (A64119)
