3rd function
/ 3rd function #1
tfehn
Louisville Ohio
Kubota BX24
Hello all Im fairly new to this site! Im trying to add 3rd function to my bx24 kubota.I would like to use a 12 volt valve. Is the bx24 open center system or closed center system? Do the work ports on the valve need to be closed in netural or open to return to the tank? Were do I tap in the system at? Does any one have a pic so I make sure I use the right lines? I've been looking on surplus center at valves and the d03 subplates. Just would like to make sure im buying the right things. I see that you can purchase the 3rd function from a couple of places but I really like doing things my self and would like to save $$$. All help would be much appreciated.:)
/ 3rd function #2
Your hyd system should be open center.
What is the purpose of your 3ed function valve?
Do you have the owners or parts manual for your tractor?
If you have a FEL, the 3ed function valve can be inserted in the PB line. The 3ed valve valve also has no relief, so a relief valve up stream will help protect the hyd system.
You will also need a DO3 subplate for the solenoid valve.
http://www.surpluscenter.com/item.asp?item=9-6136&catname=hydraulic
http://www.surpluscenter.com/item.asp?catname=hydraulic&item=9-5883-1
You might also try Baileynet.com.
http://baileynet.com/index.php
/ 3rd function
I have the owners manual for mytractor. I built a snow plow that fits on the loader over the winter. I also just got done making forks and want to add a grapple.
/ 3rd function #4
/ 3rd function
In port 4 of the quick disconnects for the fel
/ 3rd function #10
Find the thread BX25 GrappleOmatic in the build it yourself or projects forums (one or the other). Good info an details on adding a 3rd function set up to a BX.
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2022 EZ-GO ELITE...
Fuel Tank (A64119)
Fuel Tank (A64119)
