3rd function valve
/ 3rd function valve #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I have a diverter valve controlling a grapple on an M7040. It does not work the way I want, and I'm going to a true 3rd function valve.
J_J has recommended this valve for that purpose several times when the question has been raised here.
12 VDC 10 GPM OC DA SOLENOID VALVE
This valve flows 10.5 gpm. My tractor has max flow 11.1. Close....BUT, I've read in this forum you want any valve to flow what your max gpm that your tractor does. J_J in a private message says it will work fine, since you don't get max flow without max rpm and seldom do you run that....and I don't, not even close. The price is very reasonable, relative to other valve options.
Has anyone used this valve on an M7040? Does anyone see an issue in using giving the flow rates I mention? It does seem reasonable what J_J is saying.....but I want to be sure. I made a mistake buying this diverter valve, and I don't want to make another.
/ 3rd function valve #2
Most third function implements(snow plow,grapple)don't require a lot of flow.As long as you aren't trying to run a hydraulic motor you should be alright.
2004 John Deere 8320 (A63688)
2004 John Deere...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2019 F150 (A61306)
2019 F150 (A61306)
7102 (A61567)
7102 (A61567)
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
