Front-End Loader 3rd function uses...
/ 3rd function uses... #1
BLSXJ
Pembroke, Ontario
Kubota L3400
I'm looking into adding some auxiliary hydraulics to my L3400. so here is my question.
what do you use your 3rd function hydraulics for? besides a grapple.
/ 3rd function uses... #2
Those 4-in-1 buckets use the third function.
I've wondered, as I am looking now at tractors with FELs, whether it would make sense to put a hydraulic motor on the FEL frame to drill post holes. This then could use the third function connections. Our soil doesn't really have rocks, and it goes OK with a two stroke post hole digger, but can be a bit tiring and smelly.
/ 3rd function uses... #3
In addition to my grapple, I use the 3rd function for the power angle function on a snow plow, and with an SSQA to 3pt adapter, a cinder spreader, stone rake and a cement mixer.
Be aware that some 3rd function valves can overheat and are not meant for continuous duty. Care must also be used when operating hydraulic motors. The instant on / off action stops the motor abruptly and does not allow for spin down. In some cases, the use of a crossover relief valve is necessary.
/ 3rd function uses... #4
Hydraulic forks, grapple, water valve actuator for my watering can (1000 L tote), tree spade.
My tractor only puts out less then 10L/min of hyd fluid and "most" 3rd function solenoid valve discourage continuous use. so things like spreaders, post hole augers and other "spinning" attachments seem to be bad idea.
So far I could see myself using the 3rd function for a grapple, snow plow angle, snow blower chute rotation, and tree puller/shear jaws.
/ 3rd function uses... #7
My third function is used to control my grapple only, so far.
/ 3rd function uses... #9
The Long Arm Tree puller and a 7' brush hog:
Pallet of Hay Tedder Tires (A64119)
Pallet of Hay...
Gleaner Variable Speed Header Drive (A63117)
Gleaner Variable...
2014 Takeuchi TB260 Midi Excavator (A61572)
2014 Takeuchi...
POLY TOTE AND CAGE (A63291)
POLY TOTE AND CAGE...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
