3rd Function on SA324/424
/ 3rd Function on SA324/424 #11
All third functions are diverters, no additional flow is created. If you are doing more than one function at a time, the flow will be diverted and divided by multiple functions. It is a matter of preference on how to use it, both work fine.
/ 3rd Function on SA324/424 #12
My "true" or "live" 3rd function valves kit from W.R.Long allows two functions simultaneously. I can open or close my grapple while also dumping or curling. It has three switch positions. An open, a close and a neutral. Some sellers and others don't mention or don't know that there are 2 types of these valves commonly added to operate some FEL attachments such as grapples. They call diverter valves third function but don't mention the true third function type. A diverter valve disables one function in order to enable another. A third function allows an additional function without disabling the other.
/ 3rd Function on SA324/424 #13
Interesting. The Yanmar kit is a diverter, where you push the button at the top of the stick to change the side to side action from curl to the additional function.
I have two attachments that I use it with: the Yanmar grapple like in your picture, and an angling snow plow. I can‘t imagine wanting to curl and angle the plow at the same time, but curling and opening or closing the grapple simultaneously would sometimes be useful.
I assume they would both essentially go at half speed if you did them at the same time, so efficiency-wise it seems the same as doing the two movements sequentially. Do you find that to be the case?
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2019 F150 (A61306)
2019 F150 (A61306)
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2023 GMC Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC Seirra...
