Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid
Sorry, just catching up on the newer posts.
I found the install instructions for the YT3 kit and see the adjustment procedure for the cable, looks simple enough.
Jaybr, hope you were able to adjust your loader functions satisfactorily.
If you cannot find TF500A anywhere, then opt for JDM J20C aka Hy-Gard.
Other options are for fluids to MEET the JDM J20C spec, not marketing hype saying recommended.
Store brands do use the licensed Ashland-Valvoline JDM J20C fluid too.
bmaverick, I believe the TF500A is low viscosity and equivalent to the Hy-Gard J20D. In any case, I am still running the Rotella HD and the tractor is functioning well. However, I have procured 5 gallons of the Yanmar TF500A and will swap over to it closer to 175 - 200 hours; presently at @116 hours. Should be sometime during Summer.
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid #12
If the TF500A is low like the JC20D, do not use it in the hot summer. It's way to thin to protect.
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid #13
Not really, but didn't spend a lot of time on it. Fortunately, mine is setup so that I can pull a pin and rotate the lockout plate out of the way to disable it when using the bucket.
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid #14
Does the manual say anything about the temperature range of it?
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid #15
Wish we knew.
   / Questions: Yanmar 3rd Function Kit for SA425 (TVK-YL210P) Installation & Yanmar TF500A Hydraulic Fluid #16
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2013 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP TRAILER (A58214)
2013 TRAVIS BODY &...
2012 International Prostar (A56435)
2012 International...
202479 (A54757)
202479 (A54757)
Entyre Chip Spreader (A57453)
Entyre Chip...
