Snow Blade 3rd function made real easy
/ 3rd function made real easy #1
enterprisebbc
Ct
2008 CK35 Kioti
I have come across a simple and inexpensive way to use a 3rd function. If you wish to have a grapple or snow plow work then here is what I found out. I have a ck35 Kioti with a backhoe and loader. There is a place that for $350 sells a kit that works off your BH. It comes complete with all the lines and mounting hdw that runs from the BH under the frame to the Loader. You use the lever on the rt side of the seat to make it work. I have the info if anyone is interested.
/ 3rd function made real easy #3
Why use hyd at the back for hyd components up front?
A 3rd function kit can go just about anywhere.
The kit price is good. Do you have a link to the store.
Sorry but hold bunch of **** happened and I havent been on for a while or to answer what I strated. OK its Michigan Iron and Equipment. Ask for Tony as he is the owner and a real nice fella. You dont need a diverter and all just this $350 kit that works off your hydro directer flow.
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
PORTA POTTY (A68842)
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65056)
2021 CATERPILLAR...
