3pt Sprayer Project
/ 3pt Sprayer Project #1
GaryBDavis
Andice, Texas
I've mostly finished my 3pt sprayer project and thought I'd share some photos of it.
It's a 230 gallon tank. The frame is home made for category II. The pump is a typical roller style PTO pump that will put out 12GPM at 100PSI.
I wanted to be able to use it in different configurations, so I made my own "quick-tach" system. The only attachment I've made so far is for a hose reel. I made it large enough for someone to stand on (that's hand rail to hang on) so I could go around wetting down grass before burning my brush piles (or for putting out that grass fire!).
I got all my stuff at Wylie Sprayer in Waco, Texas. They were a big help.
Another rear view.
Close up of my custom "quick-tach".
The bottom of the custom "quick-tach".
The mounting plate for the control deck is bolted on so I can expand and change it if needed. I have two manual valves. When I build the spray boom, I'll add a couple of electronic solenoids. This is a manifold type set up that can be expanded by adding "sandwitching" additional valves. The small line at the end with the ball valve allows you to have a high pressue agitator line if you crack the ball valve open a bit.
/ 3pt Sprayer Project #7
WOW great job!
I sure would like to have a "Mini" version of that!
/ 3pt Sprayer Project #8
Gary that's one serious sprayer! Gotta love your quick attach system too. Nice work, thanks for sharing those great shots.
/ 3pt Sprayer Project #9
They say everything is bigger in Texas!
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
Ford Golden Jubilee (Model NAA) Tractor (A66285)
Ford Golden...
Gravely Rotary Cutter Attachment (A65640)
Gravely Rotary...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
