3pt question
   / 3pt question #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I just installed my KK Xb tiller on my Gc2610. When I adjusting it for level it seemed it would benefit from an adjustable shaft on either side of the 3 pt so I could get the tiller to raise up higher. The left side is fixed which is much longer than the right side. Has anyone put two adjustable ahafts on to increase the lift height by making both shafts shorter?
   / 3pt question #2
I just drilled another hole above the original one.
   / 3pt question #3
No reason why you can't do that. Your $'s-your choice!
   / 3pt question #4
I put an adjustable lifting link on both sides of my MF-1528, never needed it, but it was there If i did need it. Only thing was for me my lower links almost drug the ground when fully down, so I took 1 inch off the lifting links and worked out just fine. but used a high speed cut off saw and cut it very slowly.
Then took a fine file to smooth out the burr's the saw left behind on the threads.
david
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
