3PT on FX20D
/ 3PT on FX20D #1
tractorpig
Phoenix, Arizona
Yanmar/FX20D
Hello all,
I'm a newbie here and just purchased a FX20D. I purchased an operation manual and parts manual from Hoye Tractor. I had no problems for the first couple of hours and now have found that the 3PT is limp! It no longer functions! I've tried the position control and the draft control with no results. I have also played with the "stop/speed" valve with negative results. Can someone point me in the right direction, and give me some advise. I hope I haven't spent my money on just a FEL!
Thanks
Scott /forums/images/graemlins/confused.gif
/ 3PT on FX20D #2
If you purchased the tractor from a dealer contact them. Check the oil level in the trans. wen a fel is installed the oil level sometines needs to be higher then if no fel.
/ 3PT on FX20D #3
I agree with Normm, talk to your dealer. You may want to check your hydraulic filter (screen??).
Does your dealer offer any warranty or after sales support?
Good luck with your fix.
Regards, Mark
/ 3PT on FX20D #4
Nice tractor! I just picked up the same tractor two weeks ago. I just started changing the filters and fluids. My 3 point seemed a little sluggish too. I found a leak where my FEL was hooked up I fixed that and it seems to be working better. Good Luck.
/ 3PT on FX20D
I want to thank all of you for your assistance ( Normmm, mark777 and luddy). No I did not purchase this unit from hoye tractor, they helped me with additional filters and manuals. I found this unit at auction here in Phoenix. Used tractors in this area are hard to find and are priced $2,000 to $4,000 more than east of New Mexico. After a few phone calls, I went back a tightened and loosened the "stop/speed" valve several times and it's started working again..... It appears as though there may be an issue in that valve with an "0-ring" or something...I'm happy to say that everything is functioning correctly at this point....
Thanks again! /forums/images/graemlins/smile.gif
40' Shipping Container (A66285)
40' Shipping...
Concrete Cut Off Saw (A66408)
Concrete Cut Off...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
2017 CUSHMAN REFRESHER GAS GOLF CART (A63276)
2017 CUSHMAN...
