3pt lever hard to work
/ 3pt lever hard to work #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
2018 MX5200 with 400 hrs. The rear 3pt raise/lower lever is ridiculously hard to operate. Seems to be getting worse. Makes small adjustment and smooth operation difficult.
What am I missing? Thanks in advance
/ 3pt lever hard to work #2
There should be a friction adjustment for the 3 pt lever. Flow the 3 pt lever all the way down. You should see a double nut (#130 and #120) set up. If you loosen that up slightly, it will reduce the friction on the lever.
#290 is the friction disc.
#110 are spring washers to keep pressure on the friction disc
#60 is the shaft where all of this happens and where the 3 pt lever connects to.
You can also try to spray some lubricant of your choice. It should help things out but eventually dry up.
/ 3pt lever hard to work #3
if it sits outside especially, spray lube every moving joint it has.
Some quick lube spray did help. I'll look into the adjustment ptsg mentioned. Thank you all
