3Pt hydraulics question
/ 3Pt hydraulics question #1
puckgrinder85
Platinum Member
WI
'13 Yanmar Lx4100
We have a EX3200 with a backblade and an added on valve to control a bucket "thumb" i guess you could call it. There is a "out" hydraulic port near the 3pt hook up as well as a return. The "out" runs to the added on valve and obviously the return runs back through to the return line and port at the rear of the tractor. The problem we have is with this valve in here, lifting the 3 pt hitch basically moves the add on valve and much exhaust pressure, enough to where the 3 point wont lift at all. We can manually hold the lever for the add on valve in a certain spot to get the 3pt to move but obviously is a pain in the ***** and we cant be very precise with what we need to do. Is there any simple means of getting this under control? We do have a hydraulics guy in town but we have yet to get any time to consult. Would like an idea of whats involved however..
/ 3Pt hydraulics question #2
Are you trying to operate the back blade on the 3 ph the same time as the thumb on the bucket?
A pic would be helpful, but from the description, I don't follow. :confused3:
/ 3Pt hydraulics question #3
If someone plumbed the open center valves correctly, and with the valves in neutral, the fluid should flow from pump, through all the valves to tank. The 3pt should work normally. All the valves should be in series. The last valve should be the 3pt.
Well the valve is centered but as soon as you apply any lever to lift the three point hitch the valve moves over and in turn operates the thumb unless i forcefully hold the valve centered, in which the three point wil then raise. Why it moves is beyond me. I'll try to get a picture if i can. One more thing to note is the add on valve has a lock which will kick out after the thumb completely closes. Probabyl not of importance but thought i'd mention it.
/ 3Pt hydraulics question #5
sounds like the hoses are crossed on one of the valves, and I would guess it's the one that the handle is moving.
/ 3Pt hydraulics question #6
I agree, check those hoses. Appears to be hooked up wrong.
Just before i look, the feed and return hoses are on the top and bottom of the valve assembly respectively and the lines that actually run to the "thumb" are on the side of the valve body which seems correct to me, but i'll look at it closer for any markings at all. I even disconnected teh thumbs' hydraulic lines after the valve and operating the 3pt still moves the valve. I wonder if the valve has some sort of pilot thats causing this movement (remember i said it will kick out automatically after it closes fully).
/ 3Pt hydraulics question #8
Actually, most valves have pressure and return on the side, and the work ports off the top.
Look on the valve for some lettering, like IN or P
T or PB. work port may have A , B .
/ 3Pt hydraulics question #9
I had the exact same symptoms of a valve moving itself by the internal hydraulic pressure years ago when I added a hydraulic boom to the rear of a Terratrac bulldozer. I had used the "return" from the blade valve to the "in" of the new boom valve (the valves in series). When I would push the handle to the boom valve as soon as it started to pick up a load (devolope pressure) the blade valve would move itself from the internal pressure on the spool of the valve. As you say if I held the blade valve in its center position the boom would operate as intended. I solved the problem by changing the blade vale (the valve closest to the pump) to a power beyond valve. This power beyond valve is designed to handle the pressure of another hydraulic system beyond it.
I think you need to change you new valve to a power beyond type.
/ 3Pt hydraulics question #10
puckgrinder85,
How about some pictures of your valve top, sides, and bottom.
Will do as soon as i find the tractor, apparently my dad stole it to do some work at his house. I'll have to run out and look tommorow.
Well I took a closer look at the "add on" valve. I scraped a few numbers off of it but really couldnt find anything on the valve other than its made by "Energy" hydraulics. They do have a website but i still do not see the model numbers crossing over anywhere. Story it short the valve looks to be installed correctly. The "out" at the rear of the tractor runs into the "inlet" side of the valve. The "outlet" of the valve then returns back to the rear of the tractor labeled "return". Then of course the output lines simply run off the side of the valve body. I think the wrong valve is being used and may just need the correct one from what im seeing, its plumbed correctly and getting a picture will be almost impossible as its mounted inside the fender and i dont think that will do any good honestly. There are a few numbers on the valve. 1008U was the number i figured was the model # but nothing came up in any searches anywhere. Maybe i'll email energy and see what i can scrounge up. I'll update when i figure it out, probably needs the power beyond valve, it makes sense and sparks something from tech school hydraulic class.
Well here is some new info. It seems as though the add on valve for my tractor "grapple" or "thumb" is commonly used for a log splitter set up..
Here is the valve specs:
Log Splitter Valve and Accessories by Energy Manufacturing Company, Inc.
What type of valve would i need to over come this. The add on valve only moves to the hydraulic kickout side when i want to raise my 3pt hitch, it does not move the other way. Would a simple standard valve work (no hydraulic kickout needed)
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2018 Freightliner Cascadia 125 Truck T/A Sleeper Cab Truck Tractor (A64194)
2018 Freightliner...
