Sprayer 3pt Hitch Sprayer
/ 3pt Hitch Sprayer #21
Standard lawn grass - a mixture of rye, bluegrass, and fescue.
/ 3pt Hitch Sprayer
I have a 50 gallon pto driven with 8-10 foot boom and 7 nozzles. One mix of 2, 4D in 50 gallons does 4 acres. I get the 2, 4D from Tractor Supply. That 2.5 gallon jug of 2, 4D will do my 9 acres and then some. Sometimes I add a wetting agent.
As others mentioned you need to rinse stuff out and oil your rollers otherwise you end up taking the pump apart to free it up. We spray once in a while meaning every few years once we got the original problem under control. Spot spraying on the off years.
Good info JimRB! The mix ratio was something I was certainly wondering about... And noted on rinsing the pump, couple of folks have mentioned that. Appreciate it!
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
