Sprayer 3pt Hitch Sprayer
/ 3pt Hitch Sprayer #21
Standard lawn grass - a mixture of rye, bluegrass, and fescue.
/ 3pt Hitch Sprayer
I have a 50 gallon pto driven with 8-10 foot boom and 7 nozzles. One mix of 2, 4D in 50 gallons does 4 acres. I get the 2, 4D from Tractor Supply. That 2.5 gallon jug of 2, 4D will do my 9 acres and then some. Sometimes I add a wetting agent.
As others mentioned you need to rinse stuff out and oil your rollers otherwise you end up taking the pump apart to free it up. We spray once in a while meaning every few years once we got the original problem under control. Spot spraying on the off years.
Good info JimRB! The mix ratio was something I was certainly wondering about... And noted on rinsing the pump, couple of folks have mentioned that. Appreciate it!
2021 MULTIQUIP WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP...
bad boy zero turn 72 (A56859)
bad boy zero turn...
John Deere 50 (A60462)
MACK MDRIVE TRANSMISSION (A60736)
MACK MDRIVE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
Eagle Weathervane (A55853)
Eagle Weathervane...
