3pt hitch snowblower
/ 3pt hitch snowblower #1
deadeyejedi
saratoga springs ny
yanmar sa424
I was wondering if anyone could recommend a snowblower attachment for my yanmar sa424 . 23 engine hp and 18 hp at the pto .would like to go at least 54 inches wide if possible . Thank you
/ 3pt hitch snowblower #2
My FIL has run a Farm king blower at least that wide on his YM 2310 for years
the 2310 has 22.7 engine HP probably very similar PTO power.
Wish I could remember how wide the blower is , I know it is at least as wide as his tractor width with AG R1's on the rear
/ 3pt hitch snowblower #3
Your close enough to Whites Farm Supply that you could pick up a 48-60 inch Pronovost Puma from Art White.
The 48 inch Puma will work well with your tractors PTO horsepower.
/ 3pt hitch snowblower #4
If it's not hydro drive I wouldnt suggest one.
/ 3pt hitch snowblower #5
My 3 pt. blower is exactly 54” wide, and I bought it from Kubota for my Kubota BX 25. The tractor was 48 inches wide, and I put two, 2 inch spacers, which makes the rear wheels now 52 inches wide. I added wings as drift cutters, which make the blower stick out another three or 4 inches.
This rear blower is a very sturdy and powerful blower, and my BX 25 only has 17.5 PTO horsepower. But I would caution you to pack down the snow at the beginning of the season a little bit wider than you need, so that the wheels don’t fall off of your packed snow into the soft stuff that has not been driven on. What I mean is, for the first few snowfalls of the year, when you just drive over the snow to pack it down and get a good base, make sure that base is wider than the width that you plan on blowing.
/ 3pt hitch snowblower #6
I have a Farm King 600 which is 60" wide. I have run this on my old 4110 which is only 17hp at the pto. It would bog it down a bit in wet heavy snow but never really had any trouble with it. I just traded in my 4110 for a 2038R so I'm sure it will run great with the 2038R compared to the 4110.
/ 3pt hitch snowblower #7
If you don't have drifts to deal with over 2' tall, a smaller pull type blower would work well. And driving forward you would more than likely not be doused with a roostertail over your neck if you got ROPS?
I spoke with whites today they have a pronovost lynx 52 and a lynx62 reasonably priced I may go take a look
/ 3pt hitch snowblower #9
If your mule has creeper gears for reverse, you will not be disappointed
in either one as they are high quality machines.
Just remember that you should take half cuts in deep heavy snow pack
after the first pass as the machine will be able to run at the PTO engine
speed without bogging down.
If you use fluid film on the impeller paddles and the chute you will double
your casting distance.
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
3Pt Backhoe (A66285)
John Deere MX5 (A64126)
John Deere MX5...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
