3pt hitch link refurbishment
/ 3pt hitch link refurbishment #1
Valbird
Replacement ball joints are commonly available for 3pt hitch lower arms, and also for the top link.
What do people use to weld them? Just cut out the old, clean things up and fit the new ball assembly, and then something like 7018 to attach the new ball joint outer ring?
/ 3pt hitch link refurbishment #2
Generally 7018 is a good all around rod. If you're not sure what the base metal is, 309 stainless steel works well too.
/ 3pt hitch link refurbishment #3
Actually, if you bevel them and get them to meet up right, you can use 7014 or even 6013 quite well. In fact, having done this before multiple times, I'd recommend it. 7018 will work, but it's probably overkill unless you are using it on a 150hp tractor.
/ 3pt hitch link refurbishment #4
Good fit up and use whatever rod you are comfortable with. I am doing a 3pt build for my M. Probably will be fabbing links this weekend. I will use 6010.
I take it from the responses that many people replace the ball joints. My neighbor argues it's not worth it; just buy a new link.
I guess that's why I got a welder once.
Thanks for the comments!
Case IH Onland 3pt 6 Bottom Flip Plow (A64119)
Case IH Onland 3pt...
UNUSED WOLVERINE MSG-11-44W-44" GRAPPLE (A64281)
UNUSED WOLVERINE...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2022 EZ-GO ELITE...
2015 HAMM H11IX PADFOOT ROLLER (A64279)
2015 HAMM H11IX...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
