3pt hitch haunts
/ 3pt hitch haunts #1
rickv3
chelmsford
1983 1710 ford compact 4x4 diesel
Hi folks, I have a 1983 ford 1710 compact tractor, when implement is lifted in the highest position the equipment haunts (shakes), and when left in the lift position and tractor engine off it does not stay up, if loader is raised the same happens but takes awhile, this all started when the tractor went through the ice on one side had a backhoe lift the tractor out of ice and I think we forced the snow blower on the 3pt hitch against ice, any help will be appreciated, thanks in advanced
rickv3
/ 3pt hitch haunts #2
If you raise the 3pt up an shut off the engine and it descends over night, then the 3pt piston seals are worn or the 3pt valve is leaking.
If you raise the 3pt and shut off the engine and turn the descend/transport valve closed, and the 3pt drop over night, then the problem is the seals on the piston.
/ 3pt hitch haunts #3
Make sure you are not placing the lift lever in that little notch at the top.
/ 3pt hitch haunts #4
It's that time of year.
Bruce
/ 3pt hitch haunts
I thought the notch was the neutral position
Regards
Rickv3
/ 3pt hitch haunts
Good advise J.J. I guess next step is to take apart and fix, I thought it would be a more simpler solution LOL
Regards
Rickv3
/ 3pt hitch haunts
Hi J.J. the descend/transport valve is that the flow control valve
Regards
Rickv3
/ 3pt hitch haunts #8
It is a flow control valve as it relates to the 3pt.
That valve will control the descend speed or lock the 3pt in position.
/ 3pt hitch haunts
Thanks J.J. now I have to get to work, one more question, I reside in Ontario Canada, would you know of any dealers for parts or any in the USA
/ 3pt hitch haunts #10
That notch is not neutral, it is only used for auxiliary items such as a log splitter.
/ 3pt hitch haunts
Thanks for the info Wolfy
ATS Mini Excavator (A66285)
ATS Mini Excavator...
New/Unused Wolverine 66in Quick Attach Rock Bucket (A65583)
New/Unused...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
SARLO (A64557)
SARLO (A64557)
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
