3pt Finish Mower Durability?
/ 3pt Finish Mower Durability?
Re: Finish Mower Durability/Roto Tiller ?\'s
Bird- Thanks for the recommendation. I wonder if you or anyone else would like to share their thoughts on Kubota's conservative (?) implement limitations? I suspect the other tractor makers also do this, yes/no? I don't have my manual in front of me but I think Kubota's Implement Limits Chart indicates a 500lb. limit for almost all 3pt tools, a 48" limit on rotary cutters (which I'll be breaking big-time with the SQ600!) and a 50" limit on roto tillers. I opted for the SQ600 because two Kubota dealers, with some gentle reservations, said the B2710 could handle it and I really want to cut at least as wide as the tractor. And from many of the posts I've read here on TBN it seems many of us have exceeded the manufacturer's guidelines and are not reporting problems. Is this just a major case of "cover your a**" on the part of tractor/implement makers? Will careful operation and good maintenance offset the possible hazards of exceeding these limits?
Thanks Again- Dave
/ 3pt Finish Mower Durability? #22
In our area (central Maryland) CT Farm and Country has changed to QT Farm and Country (QT for Quality or QT for Quitting - seems every time I go in there there's a new group of employees)
Steve
I probably don't need to say this but I replied to RichZ privately. The QT, CT or whatever place he was considering was NOT the one I visited. The place I visited has done me no wrong or harm and I see no purpose in specifying where this business is located, in this very public forum. Though I suppose, if this chain keeps changing hands or names that this might help explain why the store I went to is in such poor shape.
I guess I feel a little better /w3tcompact/icons/smile.gif.
Dave
/ 3pt Finish Mower Durability? #24
Dave, I do believe the tractor manufacturers are a little conservative on their implement limitations. But I guess they have to assume that you're always going to be working in the most severe conditions possible. I do read and take into consideration their limitations, but then I also consider my uses and experience. I'm using a narrow tiller, offset, because I had it before I bought the B2710 and it works too well for me to spend the money to buy a bigger one, but there's no way I would go out and buy a tiller, rotary cutter, finish mower, rake, blade, or box blade that wasn't at least as wide as the outside of my rear tires. And I'm using a 5' box blade, 5' rotary cutter, and 5' finish mower, and none of them are a bit too large for my tractor.
<font color=blue>a 48" limit on rotary cutters (which I'll be breaking big-time with the SQ600!)</font color=blue>
I had an SQ48 when I had the B7100 (manual called for only a 42"). When I went to the B2710, I promptly traded for a 5' rotary cutter. In my opinion the SQ600 is exactly the right size for a B2710.
Bird
/ 3pt Finish Mower Durability? #25
Quality Farm & Country, et al...
I've been a loyal customer of Central Tractor Farm & Family for years. About 2 1/2 years ago, Quality Farm & Fleet merged/bought out Central Tractor. The stores progressively got worse in appearance, lacked inventory, had bare shelves... All the while, I was told it was "gonna get better" when in fact it looked like it was going down the tubes...
The older employees bite their tongues, but you could see them struggling not to say anything. They indicated "new corporate management" were going to make major changes...But when?
Finally at the beginning of this year 2001, it appears to be turning around... I mean you can even buy a hitch pin for your tractor now... Well I'll be... at a farm store no less, can you imagine that!
They got rid of junk Howse implements {yes I even own one}, brought on KingKutter and finally started stocking the shelves again with tractor supplies they first pulled off...
I hope they pull through and make it, because it keeps everyone else honest and competition usually keeps the pricing in-line... We'll see...
{Cobleskill, Amsterdam, & Pittsfield stores are in my area}
/ 3pt Finish Mower Durability? #26
Re: Quality Farm & Country, et al...
I've been generally satisfied with our Quality Farm. Today is 10% off day for "ThankQ" members which I'll hit tonight. Too bad I've already spent my implement bucks for the time being, but one can always use more chain and such /w3tcompact/icons/smile.gif
Right down the street is TSC, but this particular store is pretty bad. Very disorganized inside and only carry junk implements with no name brand on them. Assuming you can find your item and are satisfied with the quality level, they are cheaper. Other TSC stores I've been in are in better shape /w3tcompact/icons/smile.gif
Bird- Thanks again! Myself and I'm sure many others really benefit from your experiences and your willingness to share them.
FWIW, I think I'll probably look for a tiller I can offset in the 50"-58" range. I like the idea of being able to till close to vertical objects like trees and fences. We have close to 1000' of split rail fence that we want to make planting beds next to and this width range should work well for that purpose. With the lousy soil we'll have for a few years, our vegetable garden will be fairly small. Also, by keeping the size down I can keep the price and the load on the tractor down a little bit.
I picked up a brochure on a Kuhn #EL32 series tillers that looks pretty good. Anyone have experience with these? They're pretty heavy compared to some others I've looked at and they're available in 42", 50" and 58" widths.
Thanks Again- Dave
/ 3pt Finish Mower Durability? #28
Dave,
I'm looking at tillers too and among them checked out the Kuhn EL32-150. It is a beautiful tiller and very heavy, but based on the quote I got...you pay for it!!! If you have the $$ go for it.
Kevin
/ 3pt Finish Mower Durability? #29
Dave; I'm curious why you would want a rear discharge finish mower; i have been using a wheel horse for several years now, with a rear discharge deck and hate the wind row it leaves behind. of course i may tend to mow a little less than i "need" to..i like being able to get close on both sides but thats it..i would rather not have the wind row..
heehaw
HeeHaw- Cool name and interesting question! I chose a rear discharge finish mower to minimize exactly what you hate! According to the manufacturers literature and reports from TBN members windrows should be much less noticeable with rear discharge than a side discharge mower. I don't want to use any kind of grass collection system. Only people in low flying aircraft can see our lawn so I'm not trying to keep up with the Jone's or anyone else /w3tcompact/icons/smile.gif. I guess time will tell if the reports are true as I'm getting both the mower and cutter in two days!
Another FWIW... one reason I opted to go with good, respected brands was for the "trade-in-ability" or "used saleability". If either of these implements turn out to be a disapointment or I decide the 72" deck would've been a better choice I hope I won't be out too much extra $. This summer will be a huge learning experience for me and I'm looking forward to it/w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif.
Dave
/ 3pt Finish Mower Durability? #31
Dave:
I recently became a Compact owner and wrestled with the Tiller Brands out there. Asked quite a few folks in Southern Indiana what they recommended (did not know of this site until a couple weeks ago).
Anyway, I purchased a RTS (74") to go on my TC45D. It has an 18" offset as well. Have been pleased with the 4-5 hours I've put on it; however, it is clear that I either need to coax a farmer out of the fields (*not likly this time of year) with his plow/cultivator or buy a small one myself. I till about 6-7 acres which is in food plots of not more than about 1/4-1/2 acre each. In those area which have been worked prior to me buying the land...the tiller works great, but when I get into the areas where nothing but fescue has lived for 20+ years, the tiller only bites in about 3-4 inches after repeated passes. At this point, I am considering purchasing a Middle Buster to break things loose before using the tiller.
Anyone have any thoughts on whether this would work? Soil varies from slight clay to no clay. All well drained.
Paul
/ 3pt Finish Mower Durability? #32
Paul, I think the RTS will do the job if you make enough passes, when the moisture content is right, but I certainly agree that tearing it up first with a plow is the best way. A middle buster is a good, cheap way to do the job. In my opinion, a moldboard or turning plow is even better, but they cost a bit more.
Bird
/ 3pt Finish Mower Durability? #33
Bird:
Thanks for the advice. Have decided I need to take a trip to the local Rural King & Quality Farms stores this weekend and price out the Moldboard and Middle Buster. A couple of the guys I spoke to around here have suggested I go with the Moldboard if I can afford it....said while I could get the job done with the buster, it would take more time/effort on both me & tractor.
I'll let you know what I find out.
Paul
Paul- Welcome to the TBN community and congratulations on your recent tractor purchase! Also, thanks for your input. Yesterday I got my first tiller quotes, from yet another area dealer, on the Bush Hog RTS50 and RTS62. The place I'm getting the mower and cutter from also sells Kuhn and Woods products but I didn't see any of their stuff in stock. This dealer has recently merged with two other places so they seem to be sorting out the lines they want to carry. Right now they have a lot of Bush Hog and Land Pride in stock.
<font color=blue>I recently became a Compact owner and wrestled with the Tiller Brands out there. Asked quite a few folks in
Southern Indiana what they recommended (did not know of this site until a couple weeks ago).<font color=blue>
<font color=black>Hey, I grew up in Bloomington, IN and my mother was raised on a farm in Carlisle, IN (nothing but sandy soil there!). In my heart I'll always be a Hoosier /w3tcompact/icons/smile.gif. Are you anywhere close to Carlisle?
Tractor On- Dave<font color=black>
PS- Good luck busting up that soil!
/ 3pt Finish Mower Durability? #35
Re: Finish Mower Durability/Hoosier Humor
Here's some humor for us Hoosiers (sorry about all the >>>)...
Subject: You know you're from Indiana when...
> > > > > >-You think the State Bird is Larry.
> > > > > >-You don't know what a "Pacer" is
> > > > > >and have never even wondered.
> > > > > >-You know that "Mellencamp" went to
> > > > > >"Cougar" and back to "Mellencamp".
> > > > > >-You can say "French Lick" without
> > > > > >laughing out loud.
> > > > > >-There's actually a college near you
> > > > > >named "Ball State".
> > > > > >-You know Batesville is the "casket
> > > > > >making capital of the world", and
> > > > > >you're proud of it.
> > > > > >-The last "g" is silent in any word
> > > > > >ending in "ing".
> > > > > >-You could never figure out "spring
> > > > > >forward-fall back", so "Screw
> > > > > >Daylight Savings Time!!"
> > > > > >-Your feelings get hurt whenever
> > > > > >someone points out the acronym
> > > > > >for Purdue University is "P-U".
> > > > > >-You know several people who have
> > > > > >hit a deer.
> > > > > >-You've never met any celebrities.
> > > > > >-You've seen all the biggest bands
> > > > > >10 years after they were poplar.
> > > > > >-Down south to you means Kentucky.
> > > > > >-You have no problem spelling or
> > > > > >pronouncing "Terre Haute".
> > > > > >-Your school classes were canceled
> > > > > >because of cold.
> > > > > >because of heat.
> > > > > >-You know what the phrase "Knee-high
> > > > > >by the Fourth of July" means.
> > > > > >-You've heard of Euchre, you know how
> > > > > >to play Euchre, and you are the master
> > > > > >of Euchre.
> > > > > >-You've seen a running car, with nobody
> > > > > >in it, in the parking lot of the grocery
> > > > > >store, no matter what time of year it is.
> > > > > >-You end your sentences with an unnecessary
> > > > > >preposition. Example: "Where's my coat at?
> > > > > >or "If you go to the mall, I wanna go with".
> > > > > >-Detassling was your first job. Bailing hay,
> > > > > >your second. Or you could stack hay, swim
> > > > > >in the pond to clean off, and then have the
> > > > > >strength to play a couple of games of hoops,
> > > > > >all in the same barn lot on the same day.
> > > > > >-You've ever had to switch from "heat"
> > > > > >to "A/C" in the same day ("Stoke the
> > > > > >fire" and "fling open the windows" for
> > > > > >the older version).
> > > > > >-You say things like "catty-wumpus"
> > > > > >and "kitty-corner".
> > > > > >-You install security lights on your
> > > > > >house and garage, then leave both
> > > > > >of them unlocked.
> > > > > >-You carry jumper cables in your
> > > > > >car regularly.
> > > > > >-You drink "pop".
> > > > > >-You know that bailin' wire was the
> > > > > >predecessor to duct tape.
> > > > > >-You know that strangers are the only
> > > > > >ones who come to your "front" door.
> > > > > >-Kids and dogs ride in the passenger
> > > > > >seats of cars and the backs of pickups.
> > > > > >-You think nothing of it in spring and
> > > > > >fall to be stuck behind a farm
> > > > > >implement driving on the roads.
> > > > > >-High school basketball game draws
> > > > > >a bigger crowd on the weekend
> > > > > >than movie theaters, IF you have
> > > > > >movie theaters.
> > > > > >-Driving is better in the winter because
> > > > > >the potholes are filled with snow.
> > > > > >-The local paper covers national and
> > > > > >international headlines on one page,
> > > > > >but requires six for local sports.
> > > > > >-Can repeat the scores of the last eight
> > > > > >IU games, but unless the MVP is a
> > > > > >Hoosier, you are not sure who he is.
> > > > > >-You can see at least two basketball
> > > > > >hoops from your yard.
> > > > > >-You can name every one of Bob Knight's
> > > > > >"exploits" over the last few years.
> > > > > >-You shop at Marsh.
> > > > > >-Damon Bailey was your childhood hero.
> > > > > >-The biggest question of your youth was
> > > > > >"IU or Purdue".
> > > > > >-Indianapolis is the "big city".
> > > > > >-"Getting caught by a train" is a legitimate
> > > > > >excuse for being late to school.
> > > > > >-The Wabash river is the "biggest body
> > > > > >of water" near your house.
> > > > > >-You know several different definitions as
> > > > > >to what a Hoosier really is.
> > > > > >-People at your high school chewed
> > > > > >tobacco.
> > > > > >-Everyone knows who the town cop is,
> > > > > >where he lives, and whether he is at
> > > > > >home or on duty.
> > > > > >-To get to school you had to drive on
> > > > > >a gravel road, a road with several
> > > > > >right-angle turns in it, or if you were
> > > > > >really lucky, over a covered bridge.
> > > > > >-People in your neighborhood really,
> > > > > >REALLY like NASCAR.
> > > > > >-You actually know what the CART vs
> > > > > >IRL debate is about and have taken a
> > > > > >side.
> > > > > >-The vehicle of choice in your area is not
> > > > > >a car, but a pickup.
> > > > > >-You are a BIG John Mellencamp fan.
> > > > > >-You've been to the Covered Bridge
> > > > > >Festival.
> > > > > >-You took back roads to get there.
> > > > > >Why sit in traffic"?
> > > > > >-To you, tenderloin is not an expensive
> > > > > >cut of beef, but a big, salty, breaded
> > > > > >piece of pork served on a bun with pickles.
Rob- Great list!! I laughed, I cried... it was better than "Cats" /w3tcompact/icons/smile.gif
Thanks Alot- Dave /w3tcompact/icons/smile.gif
/ 3pt Finish Mower Durability? #37
Thanks for the grins, Rob /w3tcompact/icons/laugh.gif !!
But what's a Hoosier?
Do they "hire-out"?
How do I know if I need something "Hoosed"?
Is it safe to be around them when they're Hoosing? ( ,,, it's not anything kinky, is it?)
Enquiring mindless want-to-know! /w3tcompact/icons/shocked.gif
Larry
/ 3pt Finish Mower Durability? #38
That stuff is only taught to kids in Indiana primary schools. We could tell you the answers but would have to kill you. Non-native transplants aren't even privy to this stuff. /w3tcompact/icons/smile.gif
/ 3pt Finish Mower Durability? #39
Dave:
Yes, I know Carlisle well (and am an IU grad to boot)! Unfortunately, I live on the wrong side of River. About 20 miles from Jasper. Lots of rock & clay on this side. Folks on west side of River got the sand (makes for some great watermelon & cantelope too).
And Rob, I enjoyed the humor. I'll have to forward to my brother (the P.U. member of the family we don't talk about).
Got enough rain last night to make it a little easier with the tiller tonight, but still gonna price out a 2 bottom this weekend.
Paul
/ 3pt Finish Mower Durability? #40
John,
You saved me 400$. Thanks. It would be nice if KK posted the capacity of the hog since its shipped dry.... Oil Brand would be nice too...... Thanks again, Mike
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
2008 EPI FRAC MANIFOLD TRAILER (A67714)
2008 EPI FRAC...
2025 XKH39 39in Hydraulic 4-Way Clamshell Bucket Mini Skid Steer Attachment (A66734)
2025 XKH39 39in...
2021 CATERPILLAR 259D3 SKID STEER (A65056)
2021 CATERPILLAR...
