Chipper 3pt Chipper
/ 3pt Chipper #1
cmhyland
Platinum Member
Woodstock Valley, CT
2000 Kubota B2910
Hey guys,
I'm interested in getting a 3pt chipper. I have a Kubota B2910.
Not looking for anything too big. I'm looking to stay under 1500 bucks if possible. 4 to 5 inch capacity would be fine.
4 to 5 inch wood is firewood at my house.... so I'd be generally working with smaller stuff.
Would like a shute to direct chips.
Any idea's, websites with models and prices?
Regards,
Chris
/ 3pt Chipper #2
If you search for "chipper" in the Attachments forum, you'll find lots of information. Here's a recent thread .
/ 3pt Chipper #3
If you want a 3 pt. wood chipper that will work all day after day and live a long time, one will, a Vermeer. Salsco and Bandit make good chippers as well. The Valby is unproven yet but the design is similar to all the others. In development are the CCM 3 pt. chippers for compact tractors for 4-6" logs. The target retail price is less than $2000 for the manual feed and less than $2500 for the hydraulic feed. Expect them to be available for the fall of 2004.
/ 3pt Chipper #4
We went through the 3pt chipper routine a couple of months ago. We've got a small orchard, a larger wood lot, plus a ton of general yard debris we were interested in chipping for mulch and general cleanup. The first decision for us was deciding between a chipper -vs- a chipper-shredder. Ultimately we decided on a chipper-shredder BECAUSE the smaller debris (pruning debris from the orchard, primarily) often made it through the chipper blades not fully chipped. We tested this on a number of 4-5" chippers. We then looked at the chipper-shredders from Bearcat. There are a couple of models Bearcat makes that chip and shred -- I believe they are the 70554, and 73554 (should check these on their website). The 73554 retails for approx. $3,500, but we easily negoitiated down to $3,000. This machine has been a GREAT chipper, handling up to 5" stuff with no trouble, and a shredder that makes wonderful mulch on the smaller debris. HOWEVER, we found that we've been somewhat dissapointed with the shredder because, if overloaded, it easily clogs and has to be broken-down to clean out the shredder tumbler. We understand this is not a problem with the 70554. As we've learned how to feed the shredder, we've largely gotten past this problem. The 73554 also has a fantastic blower, which has worked wonderfully (including modifying for dropping directly into a dump cart). In our search, we haven't found any 3pt chippers or chipper-shreddes in the $1,500 price range -- my guess is you'll probably have to get into the $2,500 range at least.
/ 3pt Chipper
I have looked at ones in the 2500 to 3000 range. They're nice just a little more than I wanted to spend.
I did like the bearcat 70554 unit as it looked small and easy to store. THe Valby and Patu models are very large and won't fit inside with my machine.
Regards,
Chris
/ 3pt Chipper #6
From all I've heard, the 70554 is supposed to be a great chipper shredder. It's basically the same chipper as on the 73554, and the shredder is simpler/works better. The biggest downside is the availability of a blower -- the blower they make for it is a smaller (I think 4") unit, and it's mighty pricey (around $1,000, I've heard).
/ 3pt Chipper #7
EFC in Washington state is still advertising a unit for $1600 that looks pretty good.
/ 3pt Chipper #8
Just a couple of comments on Valby. Valby has been around a long time and are very well proven,extremely reliable smooth running chippers. I ran a Valby 150 for about 10 years on my Ford 2120 until I traded up to a Valby 160 with hydraulic feed. I have tried out a few other brands and find the Valby to be at the top of the heap. As far as storing it, the footprint is quite small.
Any ohter questions, just ask. Andy
/ 3pt Chipper #9
Hey guys, hope you don't mind if I add my two cents.
The Valby and Bearcat are both good units. If you want hydraulic feed I prefere the Valby over the bearcat. If you want the heavest duty and best preforming unit the Salsco 824 and 826 have it hands down. If you have not tried one you should. The Patu is a well made unit but lacks the desired throwing ablity because it is direct drive and only turns at 540rpm the Salsco, Bearcat and the Valby spin at about 1000+- rpm. (less chance of it cloging.)
Good luck guys
Chipperman /forums/images/graemlins/cool.gif
/ 3pt Chipper #10
I've got a Patu DC 40 that I run off my B2910 and am very happy with it. Regarding 540 RPM versus 1000+ RPM, I was concerned about that difference when I first bought my Patu, but after several years of use, I can confidently report that it's immaterial. I've chipped everything from small to large, hardwood to softwood, pine needle branches, leaves, the works. The blower/chute reliably creates a pile 15-20 feet from the chipper, and it's never clogged up, not even once.
It's once of my favorite implements, but that's like choosing between your children.
Peter
/ 3pt Chipper #11
I sell and use that same chipper. Good solid unit. We've chipped up to 5" apple in it running off a 26 PTO HP tractor.
Check with Coastal Tractor and Equipment, 203 877 6606, link. He's in Milford, CT.
/ 3pt Chipper #12
I have had a Bearcat 70554 Chipper/Shredder and two-speed blower since fall of 2000. I am using it on my Kubota B2400. I have been (slowly) clearing several acres of 12-year-old saplings as well as general clean up. Most of the 12 year saplings are tall and straight so they are well suited for a chipper. I chose this unit since it offered both the capability to chip as well as shred. I wanted the shredder to shred compost and paper for mulch and compost as well as the chipper to chip the saplings.
The 70554 can easily chip 4-inch trees. With taller trees (over 10 feet tall) or larger diameter trees (5 inch by 8 foot), the trees feed a bit too fast for the power available and stall the tractor. I have found that if I support some of the weight of these larger trees and slow down the feed rate or simply cut the trees in half or thirds before chipping it works fine. A unit with hydraulic feed would be an advantage, regulating the feed rate automatically.
I have not been happy with the blower.
The screen can not be cleaned if the blower is installed. The blower housing assembly covers the screen and must be removed to clean or change the screen. After removing the blower housing the screen comes out easily with two bolts through the bottom. The manual states that the blower should only be used with the chipper (and dry leaves going through the vacuum and the shredder). From my experience, with the blower installed, any moist material in the shredder will clog up the blower and screen. I have also had problems with small twigs about 1/8 inch in diameter falling through the shredder hammers and clogging the screen and blower. These twigs are unavoidable when chipping saplings.
The blower assembly also covers the access port used to remove the knives for sharpening. It is necessary to remove the blower and screen to sharpen the chipper blades.
The manual recommends sharpening the knives every 10 hours of chipping. The chipper self feeds as the blades grab and pull the branch into the knife. The self-feed will become less reliable as the knives dull. When the knives are dull the 70554 will kick back and throw the last piece of wood back at the operator. (Don't stand directly behind the feed chute.) All this means after a day or two of use the blower must be pulled off to sharpen the knives.
The first year I had the blower installed most of the time. Since then I have not reinstalled the blower. It is just too inconvenient to use.
Little changes in the design could have made the blower far more convenient, but overall the blower on this unit is an afterthought. It is not well integrated. For example the drive pulley for the blower is installed on a keyed shaft which comes out the back of the chipper with the drive pulley secured with setscrews. The drive pulley must be adjusted on the shaft to line up with the driven pulley on the blower housing. If the chipper is used with blower removed, a guard must be placed on the drive shaft (otherwise there is an exposed shaft spinning at PTO speed). The guard fits over the shaft but not over the pulley. This requires that the drive pulley be removed and realigned when it is replaced. The drive pulley must be set in position to match the driven pulley on the blower frame. Removing the pulleys requires a gear puller. Installation requires a hammer (and gear puller) to align them on the shaft. For this tractor neophyte this is a time consuming process.
Since removal of the blower is required frequently (every 10 hours) and the blower can not be used for routine shredding Bearcat should have provided an easier technique. Two come to mind to get power to the blower: a guard which fits over the pulley and a quick release for the drive mechanism. The simplest is a guard which fits over this drive pulley when the blower is not in use (in fact this could have been the standard cover with a negligible increase in manufacturing cost). Even better the drive shaft could have used a quick attach technique like the one used on a PTO spline and quick release.
Either technique would speed up the blower remove/install cycle considerably. The connection of the blower housing should also have been through some quick release and not a series of bolts.
The vacuum hose attachment is much more specialized than was apparent from the Bearcat web site and glossy brochure. I purchased this attachment with the thought that the vacuum hose feeding the shredder would be an easy way to turn and process my compost pile. (I hate turning compost with a shovel.) The manual states that the vacuum can be used ONLY for dry leaves. My experience is if the material is being vacuumed is even slightly moist (e.g. the leaves are wet at the bottom of the pile) the blower will clog up and require disassembly. The hose is very heavy and awkward.
One part of the vacuum attachment is very useful. The vacuum includes a top cover for the shredder port with a round hose fitting. This cover is very useful when chipping in the woods. The cover (without the hose) provides a safety cover for the shredder when chipping.
Overall the blower option for the 70554 is a poorly designed afterthought to the well-designed chipper/shredder. The self feed works well as long as you are not chipping more than the tractor power can handle. (My B2400 provides 18 PTO HP more power would reduce the tendency to stall with the larger saplings.) At times hydraulic feed would be nice but is not necessary.
I have seen the 74554 chipper with integral blower at my dealer and it looks like Bearcat may have fixed these problems (in a higher cost unit). The 74554 has a hinged cover that provides easier access to the knives. The better access and therefore the faster knife change could be a factor if you use the chipper a lot. It also has hydraulic feed, which will control feed rate, not require that you stand by and monitor the feed and eliminates the possibility of kickback. I think 73454 is the manual feed equivalent model to the 74554. I am not sure about the 73554.
2007 MACK CXN VISION (INOPERABLE) (A63569)
2007 MACK CXN...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2019 CAT 259D (A60462)
2017 TROXELL 130 BBL VACUUM TRAILER (A63569)
2017 TROXELL 130...
CATERPILLAR 559B DS KNUCKLE BOOM LOADER (A63290)
CATERPILLAR 559B...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
