3PL Rippers
/ 3PL Rippers #1
njrqs
Queensland, Australia
Kubota L1-20 DT
I am thinking of getting a single tyne ripper with an optional poly pipe layer attachment. This is for my small Kubota L185.
Anyone had any luck with these?
I assume the angle of the ripper is what gets it under the surface, as the 3PL obviously cannot "push" the ripper down?
Neil R.
/ 3PL Rippers #2
That is correct, Neil. The angle of the ripper causes it to self- feed. You may have to adjust the top link to get it just right. There is no downpressure from the tractor.
<font color=green>stan</font color=green>
/ 3PL Rippers
Stan
Thanks
Heard of these pipe laying attachments?
In theory it sounds OK. Probably rip once then run over again with the layer?
<font color=blue>Neil R.</font color=blue>
/ 3PL Rippers #4
Neil-
Heard of them, but never used one- they're supposed to be pretty slick- and fast. But of course the material, being bendable, will be somewhat of a compromise. A second pass might be a good idea if the soil is dry and hard- if you could keep the ripper in the track. It might be a good idea to set the stabilizers a little loose on the second pass.
/ 3PL Rippers #5
You can make your own " poly pipe layer attachment" by heating up plastic conduit on the exhaust pipe of a car or truck and gently bend it to nearly 90 degres and then attach it with multiple worm gear clamps to the ripper. Use 2" conduit for 1" poly- it takes more room than you think to feed the poly thru the conduit. I take the sweep blade off the ripper and use a spear point for a little extra depth. you may have make several passes. I bent the top link when the ripper was at depth because the top link was angled way down and ripper was trying to compress it. A chain from the drawbar to the ripper tine below the 3 point hitch plane will prevent that.
RCH
/ 3PL Rippers
Rch
Thanks for that. Considering I have no other attachments except my slasher (bush hog) I am looking for a good (cheap) additional attachment. I think this may be handy. We have very hard ground here, and digging with pick & shovel is hard. I hope the ripper to allow me to break it up. (No I can't afford a FEL !)
Do you think my 185 will handle it OK?
<font color=blue>Neil from OZ.</font color=blue>
/ 3PL Rippers #7
Hi Neil
I know what you mean about hard ground, I live in the Swan Valley W.Australia and it gets like concrete in the summer, I hired a ripper/pipe layer when I had a Leyland 245 (45hp) and it just couldn't cut the soil, the wheels just spun around, I ended up hiring a dozer to rip the whole paddock, and now that I have a b/hoe I use this to dig any pipe trenches.
Regards
Chris
/ 3PL Rippers
Chris
AGGGHH That's not what I wanted to hear but sort of what I expected to hear !
I'm in Rockhampton Qld. Looks like we all have concrete ground !
Why did you rip the whole paddock?
/ 3PL Rippers #9
Neil
I was originally going to plant olive trees on this paddock, but finding how hard and compacted the soil was I had it deep ripped to about half a metre and spread gypsum, this opens up the clay and improves aeration/drainage. I haven't planted anything up there yet but the soil does seem more friable. of course it's not summer yet !!!
Regards
Chris
/ 3PL Rippers #10
Chris-
I hope you didn't give up on the olives. I've seen them do quite well in some pretty nasty, clayey, rocky "soil".
/ 3PL Rippers #11
I have had great luck with a ripper on my Kubota BX2200. It sometimes takes 4wd to keep it moving, but does a good job of breaking up the ground. You're actually supposed to use it when the ground is dry to have more a shattering effect - helps drainage and allows plant roots to get nutrients from deeper down.
I did it for my vegetable garden in hard, compacted, clay - and my garden was dramatically better producing than my neighbors in the same type of soil. Both gardens were tilled to around 9" deep - but I had used my ripper to break up the ground before tilling. I would recommend it to anyone.
I also plan to use my ripper to break up the ground to run my downspouts away from the house ... trying to avoid bringing out the pick or renting a ditch-witch if I can.
Patrick
/ 3PL Rippers
Well fellas, look what I found in Saturday's paper !!
Seems to work fine, even on our hard ground.
$150 Aust = half price + it came with that steel flywheel for extra weight. Problem is it took 4 blokes to lift it into the ute so I am not sure what to do with it yet. Without the weight I can keep the ripper inside the shed.
With the weight on I'd have to leave it standing in the last ripped trench !
PS - Also came with the pipe laying attachment.
/ 3PL Rippers
Here's the flywheel. All 100kg of it I'd say !
/ 3PL Rippers
Well after a lot of grunting and lifting, I managed to get that weight on the ripper (along with a lot of help from my 3PL lift).
And then even managed to stand the thing up to attach it. But..... the weight is in the road of my top link.
So I have managed to bolt on a timber step to the ripper and a handy friend can jump on and act as the weight.
Pretty safe as I rip in low gear and if he fell off he would be behind the danger area.
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65057)
2023 WALLACE-THE...
2025 JMR Tree Boom Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
2005 Honda Pilot AWD SUV (A66738)
2005 Honda Pilot...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
3096 (A63117)
3096 (A63117)
2019 JCB 409-T4 WHEEL LOADER (A65056)
2019 JCB 409-T4...
