3PH Pin Width
/ 3PH Pin Width #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
I have a Cat II tractor. I just picked up a rake that is a Cat I. I can certainly hook up and use it fine. However it produced a question in my vaccum chamber.
What is the significance (if any), of the width between the pins that fit into the lift arms. Other than the obvious - larger machine, wider distance between the arms etc. -
This rake is pretty narrow between pins compared to other gadgets I own. The design of it would make it easy to fab. a new, and wider cross piece with the pins on the ends. Is it worth it? Does the added width add strength, stability, or ?? to the hookup?
Al
/ 3PH Pin Width #2
The Cat 2 hookup is bigger because the implements used on a Cat 2 tractor can be much larger than a Cat 1 setup. Larger implements means larger width. I wouldn't worry about converting your present implement unless you have to keep adjusting your side links for the smaller attachment. If that is a pain to do, then I would make it fit your Cat 2 setup so that no adjustments are neccessary to use it.
/ 3PH Pin Width #3
It's obvious to me that you just need to get an additional tractor!
/ 3PH Pin Width
"oliver28472It's obvious to me that you just need to get an additional tractor!"
Now you are a wise man.;) You must be fhysic. Why, I was saying to my wife just yesterday tha......................
/ 3PH Pin Width #5
Al
The width difference is because of the width difference where the arms fasten to the tractor. Puts the arms in a "comfortable" position to pull from with the links close to vertical. When you hook up your CAT II tractor to your narrow CAT I implement, they are not pulling comfortably. Not something that you are going to do damage with because your small CAT I implement probably won't stand the strength of your tractor anyway. If it IS an implement that will place a large load on your tractor, then you should rebuild to match the tractor width.
/ 3PH Pin Width #6
Al
Dang it, I meant to attach this chart with my other reply. Check out this handy chart if you decide to convert to CAT II.
/ 3PH Pin Width
Makes sense. Pull straight, instead of from an angle.
The rake is 7', and all 1/2" steel. I am going to add some reinrforcement, and just wanted to figure out if if it was worth it to make the pins wider, and tie it all together.
Thanks
/ 3PH Pin Width #8
It would be worth it for me just so I don't have to adjust the stabilizer bars everytime to switch from narrow to wide. My stabilizers have a hitch pin w/lynch pin ...connecting bars that slide within each other. It is a small pain to adjust because it's easy to drop and lose the pins or washers.
/ 3PH Pin Width #9
Good point 3RRL, I forgot about that!!! That is definitely a reason to convert the implement to a standard that fits everything else you hook up to.
/ 3PH Pin Width #10
Yeah Ovrszd,
If it wasn't for that adjustment, attaching any of my implements would be a snap with Pat's EZ lift system. That's the only thing (other than top link attach for some) I have to do to adjust....otherwise nothing. I may just have to standardize the lift pin width on all my implements just for that reason.
/ 3PH Pin Width #11
3RRL said:
Yeah Ovrszd,
Very good point. I plan to build several attachments when I get home and need to keep that in mind when building the hitch setup.
/ 3PH Pin Width
OK Ya' talked me into it. It should be strong enough now. I made the width of the pins same as my forestry winch, which is my default 3ph attachment.
Thanks for the help!
Al
/ 3PH Pin Width
Woops!! That was a "before " pic. This is the one I intended to post.
/ 3PH Pin Width #14
Now that definitely looks beefy!:D
Nice job!
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
