3PH Pin Width
/ 3PH Pin Width #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
I have a Cat II tractor. I just picked up a rake that is a Cat I. I can certainly hook up and use it fine. However it produced a question in my vaccum chamber.
What is the significance (if any), of the width between the pins that fit into the lift arms. Other than the obvious - larger machine, wider distance between the arms etc. -
This rake is pretty narrow between pins compared to other gadgets I own. The design of it would make it easy to fab. a new, and wider cross piece with the pins on the ends. Is it worth it? Does the added width add strength, stability, or ?? to the hookup?
Al
/ 3PH Pin Width #2
The Cat 2 hookup is bigger because the implements used on a Cat 2 tractor can be much larger than a Cat 1 setup. Larger implements means larger width. I wouldn't worry about converting your present implement unless you have to keep adjusting your side links for the smaller attachment. If that is a pain to do, then I would make it fit your Cat 2 setup so that no adjustments are neccessary to use it.
/ 3PH Pin Width #3
It's obvious to me that you just need to get an additional tractor!
/ 3PH Pin Width
"oliver28472It's obvious to me that you just need to get an additional tractor!"
Now you are a wise man.;) You must be fhysic. Why, I was saying to my wife just yesterday tha......................
/ 3PH Pin Width #5
Al
The width difference is because of the width difference where the arms fasten to the tractor. Puts the arms in a "comfortable" position to pull from with the links close to vertical. When you hook up your CAT II tractor to your narrow CAT I implement, they are not pulling comfortably. Not something that you are going to do damage with because your small CAT I implement probably won't stand the strength of your tractor anyway. If it IS an implement that will place a large load on your tractor, then you should rebuild to match the tractor width.
/ 3PH Pin Width #6
Al
Dang it, I meant to attach this chart with my other reply. Check out this handy chart if you decide to convert to CAT II.
/ 3PH Pin Width
Makes sense. Pull straight, instead of from an angle.
The rake is 7', and all 1/2" steel. I am going to add some reinrforcement, and just wanted to figure out if if it was worth it to make the pins wider, and tie it all together.
Thanks
/ 3PH Pin Width #8
It would be worth it for me just so I don't have to adjust the stabilizer bars everytime to switch from narrow to wide. My stabilizers have a hitch pin w/lynch pin ...connecting bars that slide within each other. It is a small pain to adjust because it's easy to drop and lose the pins or washers.
/ 3PH Pin Width #9
Good point 3RRL, I forgot about that!!! That is definitely a reason to convert the implement to a standard that fits everything else you hook up to.
/ 3PH Pin Width #10
Yeah Ovrszd,
If it wasn't for that adjustment, attaching any of my implements would be a snap with Pat's EZ lift system. That's the only thing (other than top link attach for some) I have to do to adjust....otherwise nothing. I may just have to standardize the lift pin width on all my implements just for that reason.
/ 3PH Pin Width #11
3RRL said:
Yeah Ovrszd,
Very good point. I plan to build several attachments when I get home and need to keep that in mind when building the hitch setup.
/ 3PH Pin Width
OK Ya' talked me into it. It should be strong enough now. I made the width of the pins same as my forestry winch, which is my default 3ph attachment.
Thanks for the help!
Al
/ 3PH Pin Width
Woops!! That was a "before " pic. This is the one I intended to post.
/ 3PH Pin Width #14
Now that definitely looks beefy!:D
Nice job!
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
John Deere Mower Model LT155 (A62679)
John Deere Mower...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
