3PH Mounted Backhoes.
/ 3PH Mounted Backhoes. #11
For several years I used a Woods 650 mounted on the 3pt of my Ford 1710. For the most part I didn't horse it, but one day I pushed it a little digging out a 24" pine stump and loosened (didn't break a casting) the transfer-tranny bond, leaking a little hydraulic. Learned my lesson. My fix was to pick up an old Cat backhoe for digging holes and sell the Woods.
I sold Massey compacts for a time and can attest to the fact that even a slightly mis-designed FEL mount can pass on enough stress to crack major castings. (Affected the 45 and 55 HP units)
If you're going to mount a backhoe on a compact tractor, seriously consider a subframe.
/ 3PH Mounted Backhoes. #12
bjr said:
I'm interested in the cad backhoe for a 354 Jinma. I was wondering if there are easly removeable subframe kind of attachment type a fellow could build? Any caddigger builders out there? bjr
Here is a an older thread about the subframe I made for Kama tractor. It also has several references to other home made sub frames.
Might give you some ideas?
Home Made Backhoe Subframe
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Ratchet Straps (A59230)
Ratchet Straps...
Service Truck Body (A59230)
Service Truck Body...
