3PH Log Splitter Rebuild ?
/ 3PH Log Splitter Rebuild ? #1
timster2
Platinum Member
North East PA
Kubota BX2230 & B2320
Built this log splitter over twenty years ago and the semi automatic, voice activated, hydraulic control valve actuator no longer functions as designed. :laughing:
I need to add a winch or hydraulic lift to get the larger rounds on to the beam, cant lift them like I use to. I bought a HF pick up truck lift to add to the end of the beam, however, I am looking for suggestions. Should I bother to put the boom on the beam or would a hydraulic cylinder and valve be a better choice? Here are some pictures of the splitter as it stands now:
DSC00041.JPGDSC00042.JPGDSC00044.JPGDSC00045.JPGDSC00046.JPGDSC00047.JPGDSC00050.JPGDSC00058.JPG
So far I have a new wedge.
Well as luck would have it I was doing some splitting before the rebuild and broke the wedge. It broke two years ago and the weld was holding until I tried to split a large knot. So the time has come to at least weld on the new wedge. The post has been out there for a while with no responses, wonder why?
/ 3PH Log Splitter Rebuild ? #3
Here's my setup, I've since rebuilt the boom as about a 5ft diameter wet cottonwood log did her in one day! But gives you an idea, Its on its own spool and works great
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
Metal Eagle Weather Vane (A66738)
Metal Eagle...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
Massey Ferguson 1754 (A64911)
Massey Ferguson...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
