3ph lever
/ 3ph lever #1
dass
This happened without warning: Lever for the 3ph is nearly set-up. The 870 JD was serviced this spring and has 480 on it now. Any ideas?????? dass
/ 3ph lever
Don't have a pic,Norm. Can't understand what has happened to make the lever so tight,takes both hands to move it. The arms will move if you're strong enough to move the handle !dass
/ 3ph lever #4
Norm, in some parts of the country, set-up means locked-up or locked in place. Like glue sets-up.
Dass, I really don't know anything at all about your JD but is it possible that the Stop Valve for the 3pt got inadvertently screwed in during the service? I am assuming that it has a Stop Valve like my Yanmar.
/ 3ph lever
Thanks Ozarker, that's a good place to start. dass
