3PH "Cradle" for Chipper/Shredder
/ 3PH "Cradle" for Chipper/Shredder #21
Re: 3PH \"Cradle\" for Chipper/Shredder
I have Troy Built 10hp that I bolted a drawbar onto, and use hooks and a pin on top link. The chipper is very top heavy and was impossible to move on hills(narrow skinny wheels).
The added advantage was the chipper is a bottom discharge,and now i can leave extra clearance under it, or level it when on hills
/ 3PH "Cradle" for Chipper/Shredder #22
tom,
what did you decide on, or have you not decided yet?
im keen to hear your solution
thanks /forums/images/graemlins/laugh.gif
/ 3PH "Cradle" for Chipper/Shredder #23
bluemule... Do you have any pictures of your setup? I like the idea of extra ground clearance.
John
/ 3PH "Cradle" for Chipper/Shredder #24
JWE, may i ask if you can post a photo of how the carryall attaches to your tractor, i like the look of what you have there for carrying logs
thanks
/ 3PH "Cradle" for Chipper/Shredder #25
my camera's at work. Will try to remember it and take pics and post....stay tuned..
/forums/images/graemlins/crazy.gif
Ralph, Mith, John, Bluemule,...et. al...
Sorry to take so long. Incredibly busy work week and we FINALLY got a little SNOW /forums/images/graemlins/grin.gif. They called it a "Storm"...at about 14" I call it a snow but, the blower took the 1st really wet and heavy 8" without breaking a sweat. Had to go a little slow as it packed and pushed if I didn't eat into it slowly. When it started to dry out, the plume of last 6+ inches shooting off into the woods was a thing of beauty.
Anyway, FINALLY got the pictures last weekend but, daughter didnt' download them 'til last night. Hopefully I can figure out how to attach them and not eat up too many bytes.
More to follow...
Tom
/ 3PH "Cradle" for Chipper/Shredder #27
I'd think that you could get yourself a drawbar from TSC and fabricate or buy (maybe from TSC) a "U-shaped" metal bracket that you could weld or bolt to the chipper about at the bottom of the hopper, to attach a top link to.
Just attach the chipper to your drawbar with a couple U bolts or muffler clamps via that little footer in front of the wheels in your photo. Actually, TSC has some U bolts and metal end pieces in a kit that I used to attach a hitch receiver to on my Gravely sulky. The U has about a 2" spread and is about 3 to 4" deep.
Check top link length you need. Shorter ones are available in the Cat 0 size.
Ralph
That was the "front" view. Here's a side.
Here's the back (or front, depending on point of view).
P.S. RALPH is that 'puter on your tractor??? I can't keep up /forums/images/graemlins/shocked.gif
Tom
And maybe a better view...
With perspective to the lift and RB..
Another angle...
Just a shot of the 4115 w/Blower and the last project (shed) I built BEFORE I had the help of the loader, backhoe, and blade (shovel, iron bar, etc. much less fun). That stone wall on the left (not a good view) was built from stones from the area of the shed...I said this land is a bit "rocky". /forums/images/graemlins/tongue.gif
One last pic...This is the deck I built about 12 years ago. All the holes for the posts were dug by hand, the excavation for the 6X6 PT steps, the 20' long PT 6X6's carried by hand (dragged is more like it) ...... would account for the shoulder surgery /forums/images/graemlins/frown.gif What idiot would build a 40' long, by 12' to 10' wide open deck in snow country??? /forums/images/graemlins/confused.gif
Ralph,
Thanks. Sounds good. I am flipping a coin over "carry-all" vs. special rig just for the chipper. I am leaning heavily to "special rig" such as you describe and save the carry-all project for later. Carry-all has its benefits for bringing the loppers, chainsaws, gas, clearing saw... However, all that fits in the FEL. If "special rig" lift, I can, as Bluemule discusses, just lift a bit for the bottom discharge, move easily to where I want it, and not have to make a special floor for a carryall to allow for discharge, or take the C/H out of the carry-all to use it.
I'll check into TSC for the kit and the shorter CAT 0 toplink. I want to see Bluemule's pic's too, before ordering parts.
Thanks all....I'll posts some pic's of snow when we get a bit more added to this last drop.
/ 3PH "Cradle" for Chipper/Shredder #36
Hey, what are you doing with my chipper? Seriously, if it was red, it would be identical to mine.The angled face on the base of the unit is where I bolted the drawbar(parallel to axle). I used hooks off old broken motorcycle tie downs(2nd generation pack-rat and proud of it)to hook onto handle on shredder hopper with top link. Will post pics hopefully tomorrow.
/ 3PH "Cradle" for Chipper/Shredder #37
I also have the same chipper and you can forget about attaching a tongue. I put one on my chipper but the wheel tread is too narrow to and it keeps tipping. The tongue might work OK if your property is perfectly flat. Another problem is that the oil drain is right where you need to attach the tongue.
The carryall works well but Bluemule's setup may be better because of the bottom discharge.
John
/ 3PH "Cradle" for Chipper/Shredder #38
Heres the pics of my set up.this one is with chipper raised for transport
/ 3PH "Cradle" for Chipper/Shredder #39
This is in lowered-operating position
/ 3PH "Cradle" for Chipper/Shredder #40
detail of drawbar mount
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
