380 shot shell
/ 380 shot shell #21
the capsule weighs 60 gr.
maybe fotobomb will let me post give me a few tries.
/ 380 shot shell #23
cci claims 53 gr of no 12 shot in the 9mm and 52 gr of no12 in the 22 mag.
they have a new 9mm with 45 gr of no 4 shot.
/ 380 shot shell
53 grains is a bit less than I was able to fit in the 380 but I suppose the plastic takes up more volume than the brass and it has a lot more ogive as well.
45 grains of #4 bird shot is only 13-14 pellets, that would greatly reduce the odds of a hit as 53 grains of #12 would be 265 pellets.
/ 380 shot shell #25
the old crimped 22 shot shells from winchester had 105 pellets in them, and weighed 25 gr-- i just checked.
cci claims 32 gr in 22 LR
but i got options- and now to measure some fireball brass.
/ 380 shot shell
Let us know what you come up with,
Here is a handy chart.
Size Type Weight Diameter
0000 Buck 82 grains 9.70 mm (0.380")
000½ Buck 76 grains 9.40 mm (0.370")
000 Buck 70 grains 9.14 mm (0.360")
00½ Buck 59 grains 8.60 mm (0.340")
00 Buck 53.8 grains 8.38 mm (0.330")
0 Buck 49 grains 8.13 mm (0.320")
#1½ Buck 44.7 grains 7.90 mm (0.310")
#1 Buck 40.5 grains 7.62 mm (0.300")
#2½ Buck 36.6 grains 7.4 mm (0.290")
#2 Buck 29.4 grains 6.86 mm (0.270")
#3½ Buck 26.3 grains 6.60 mm (0.260")
#3 Buck 23.4 grains 6.35 mm (0.250")
#4 Buck 20.7 grains 6.09 mm (0.240")
FF Waterfowl 18.2 grains 5.84 mm (0.230")
F (or TTT) Waterfowl 16.0 grains 5.59 mm (0.220")
TT Waterfowl 13.9 grains 5.33 mm (0.210")
T Waterfowl 12.0 grains 5.08 mm (0.200")
BBB Bird 10.2 grains 4.82 mm (0.190")
BB Bird 8.50 grains 4.60 mm (0.180")
BB (air gun) Bird 8.10 grains 4.57 mm (0.177")
B Bird 7.40 grains 4.50 mm (0.170")
#1 Bird 6.15 grains 4.10 mm (0.160")
#2 Bird 4.40 grains 3.76 mm (0.150")
#3 Bird 5.07 grains 3.6 mm (0.140")
#4 Bird 3.30 grains 3.28 mm (0.130")
#4½ Bird 2.90 grains 3.18 mm (0.125")
#5 Bird 2.60 grains 3.05 mm (0.120")
#6 Bird 2.00 grains 2.77 mm (0.110")
#7 Bird 1.50 grains 2.50 mm (0.100")
#7½ Bird 1.29 grains 2.39 mm (0.095")
#8 Bird 1.09 grains 2.26 mm (0.090")
#8½ Bird 0.97 grains 2.16 mm (0.085")
#9 Bird 0.75 grains 2.01 mm (0.080")
#10 Pest 0.51 grains 1.80 mm (0.070")
#11 Pest 0.32 grains 1.50 mm (0.060")
#12 Pest 0.19 grains
/ 380 shot shell
Had an idea the other day and had a few min to see how it would work.
I took a spare Lee powder through die I had and removed the flare portion from the inside and replaced it with an insert I machined to swage the 380 case down like my 45 ACP die does.
Much faster and the crimp looks a bit better.
/ 380 shot shell #28
i tried to turn a fireball case yesterday and tore it. i just need a better fit on the mandrel.
/ 380 shot shell #29
CCI does offer a 38/357 shotshell.
As for snakes, these rounds should be considered "lucky" shots. The shot content/spread makes a definite hit/kill a matter of luck. Yes, I've used the 38 shotshell on snakes but it often takes more than one round. The 44 round is MUCH more effective.
/ 380 shot shell
.221 fireball will be too thin to turn, the only reason a .223 works is because the web is so thick that low.
38/357 is a completely different round than the 380.
Speer sells capsules for the 38/357, 44 and 45 calibers but they are all for use in revolvers and would not work in this application, I know of no revolver chambered for .380 ACP.
/ 380 shot shell #31
once we made a shot shell for a 41 mag with a gas check under and over the shot.
that 45 does have an impressive pattern.
/ 380 shot shell #32
got a 221 case turned. i used an expander mandrel turned around backwards in a neck turner and chucked the case in a drill. it is thinner than a 223 but that does not appear to be a problem yet. crimping the end may be hard but i can put a wad in for sure. heck i can probably use pliers to fake an end crimp. feeding may be an issue but heck for what it needs to do we can work around that.
/ 380 shot shell #33
Tell me a little about the backstop in the.380 test video.
I'm considering setting up something with recycled rubber to harvest more lead.
/ 380 shot shell
That is 3/8" plate steel.
About 4000 lbs of it.
Gives you a large margin of error and contain all bullets sent down range.
You can make something smaller that will work too and if you add a heater you can melt the lead right out of it.
/ 380 shot shell #35
Very nice. I've been considering ground rubber with steel in a portable shed. Do you know how deep of a rubber bed it takes to catch 200grain/3000fps rounds? Google has failed me.
/ 380 shot shell
Would be quite a bit, that's fast for a bullet that heavy. Maybe deflect it with AR 500 plate on an angle first and it would take a lot less.
/ 380 shot shell #37
I have an irrigation pond we are constantly enlarging. The spoil piles have been a local shooting spot for years. Usually there is barely a trace of anyone being there, but I have found a few belted magnum cases. Lots of shotgun slug sabots I'm not aware of anyone with a .50 so I picked rough guess on a belted mag.
The snail trap needs a designated firing line. There are elevation changes from 100-200 yards that would make me nervous about entry trajectory.
What did you use for the trap? Ice got a few steel #30 (forklift size) propane tanks I've thought about. Ground rubber I can get for free free.
/ 380 shot shell
The last one I built was just for checking loads, 1/4" plate and a 1/2" thick AR 500 plate at 45 deg into sand.
Not for long range at all but function and velocity testing of production rounds lot of lot. It's inside a sound deadened conex. Uses an Oehler 35 with holes cut for the sensors, lights and one for the exhaust fan.
So testing can be done in the same building as production with 8" of sound deadener all around.
/ 380 shot shell #39
been setting around in the cold and finally got to put together some snake shot. i never could hold tight enough tolerance to turn down a 223. darn! wish i had some done but ...
i pulled some 9 mm shot capsules and had to cut off about 130 thou. tedious but i did not bust a single capsule.
they cycle but i have not been rough on them and have not shot any yet. looks promising anyhow.
/ 380 shot shell
I took a Dillon powder die and machined another insert for it to form the cases, from cut .223 cases.
It's a lot faster than turning each case and works just as good. The one on the right is what they look like after being fired.
John Deere 6110M (A53317)
John Deere 6110M...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
