380 shot shell
/ 380 shot shell #31
once we made a shot shell for a 41 mag with a gas check under and over the shot.
that 45 does have an impressive pattern.
/ 380 shot shell #32
got a 221 case turned. i used an expander mandrel turned around backwards in a neck turner and chucked the case in a drill. it is thinner than a 223 but that does not appear to be a problem yet. crimping the end may be hard but i can put a wad in for sure. heck i can probably use pliers to fake an end crimp. feeding may be an issue but heck for what it needs to do we can work around that.
/ 380 shot shell #33
Tell me a little about the backstop in the.380 test video.
I'm considering setting up something with recycled rubber to harvest more lead.
/ 380 shot shell
That is 3/8" plate steel.
About 4000 lbs of it.
Gives you a large margin of error and contain all bullets sent down range.
You can make something smaller that will work too and if you add a heater you can melt the lead right out of it.
/ 380 shot shell #35
Very nice. I've been considering ground rubber with steel in a portable shed. Do you know how deep of a rubber bed it takes to catch 200grain/3000fps rounds? Google has failed me.
/ 380 shot shell
Would be quite a bit, that's fast for a bullet that heavy. Maybe deflect it with AR 500 plate on an angle first and it would take a lot less.
/ 380 shot shell #37
I have an irrigation pond we are constantly enlarging. The spoil piles have been a local shooting spot for years. Usually there is barely a trace of anyone being there, but I have found a few belted magnum cases. Lots of shotgun slug sabots I'm not aware of anyone with a .50 so I picked rough guess on a belted mag.
The snail trap needs a designated firing line. There are elevation changes from 100-200 yards that would make me nervous about entry trajectory.
What did you use for the trap? Ice got a few steel #30 (forklift size) propane tanks I've thought about. Ground rubber I can get for free free.
/ 380 shot shell
The last one I built was just for checking loads, 1/4" plate and a 1/2" thick AR 500 plate at 45 deg into sand.
Not for long range at all but function and velocity testing of production rounds lot of lot. It's inside a sound deadened conex. Uses an Oehler 35 with holes cut for the sensors, lights and one for the exhaust fan.
So testing can be done in the same building as production with 8" of sound deadener all around.
/ 380 shot shell #39
been setting around in the cold and finally got to put together some snake shot. i never could hold tight enough tolerance to turn down a 223. darn! wish i had some done but ...
i pulled some 9 mm shot capsules and had to cut off about 130 thou. tedious but i did not bust a single capsule.
they cycle but i have not been rough on them and have not shot any yet. looks promising anyhow.
/ 380 shot shell
I took a Dillon powder die and machined another insert for it to form the cases, from cut .223 cases.
It's a lot faster than turning each case and works just as good. The one on the right is what they look like after being fired.
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2015 Ford F-150...
2014 Freightliner Cascadia 125 S/A Day Cab Truck Tractor (A59230)
2014 Freightliner...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
208320 (A58375)
208320 (A58375)
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
