380 shot shell
/ 380 shot shell #21
the capsule weighs 60 gr.
maybe fotobomb will let me post give me a few tries.
/ 380 shot shell #23
cci claims 53 gr of no 12 shot in the 9mm and 52 gr of no12 in the 22 mag.
they have a new 9mm with 45 gr of no 4 shot.
/ 380 shot shell
53 grains is a bit less than I was able to fit in the 380 but I suppose the plastic takes up more volume than the brass and it has a lot more ogive as well.
45 grains of #4 bird shot is only 13-14 pellets, that would greatly reduce the odds of a hit as 53 grains of #12 would be 265 pellets.
/ 380 shot shell #25
the old crimped 22 shot shells from winchester had 105 pellets in them, and weighed 25 gr-- i just checked.
cci claims 32 gr in 22 LR
but i got options- and now to measure some fireball brass.
/ 380 shot shell
Let us know what you come up with,
Here is a handy chart.
Size Type Weight Diameter
0000 Buck 82 grains 9.70 mm (0.380")
000½ Buck 76 grains 9.40 mm (0.370")
000 Buck 70 grains 9.14 mm (0.360")
00½ Buck 59 grains 8.60 mm (0.340")
00 Buck 53.8 grains 8.38 mm (0.330")
0 Buck 49 grains 8.13 mm (0.320")
#1½ Buck 44.7 grains 7.90 mm (0.310")
#1 Buck 40.5 grains 7.62 mm (0.300")
#2½ Buck 36.6 grains 7.4 mm (0.290")
#2 Buck 29.4 grains 6.86 mm (0.270")
#3½ Buck 26.3 grains 6.60 mm (0.260")
#3 Buck 23.4 grains 6.35 mm (0.250")
#4 Buck 20.7 grains 6.09 mm (0.240")
FF Waterfowl 18.2 grains 5.84 mm (0.230")
F (or TTT) Waterfowl 16.0 grains 5.59 mm (0.220")
TT Waterfowl 13.9 grains 5.33 mm (0.210")
T Waterfowl 12.0 grains 5.08 mm (0.200")
BBB Bird 10.2 grains 4.82 mm (0.190")
BB Bird 8.50 grains 4.60 mm (0.180")
BB (air gun) Bird 8.10 grains 4.57 mm (0.177")
B Bird 7.40 grains 4.50 mm (0.170")
#1 Bird 6.15 grains 4.10 mm (0.160")
#2 Bird 4.40 grains 3.76 mm (0.150")
#3 Bird 5.07 grains 3.6 mm (0.140")
#4 Bird 3.30 grains 3.28 mm (0.130")
#4½ Bird 2.90 grains 3.18 mm (0.125")
#5 Bird 2.60 grains 3.05 mm (0.120")
#6 Bird 2.00 grains 2.77 mm (0.110")
#7 Bird 1.50 grains 2.50 mm (0.100")
#7½ Bird 1.29 grains 2.39 mm (0.095")
#8 Bird 1.09 grains 2.26 mm (0.090")
#8½ Bird 0.97 grains 2.16 mm (0.085")
#9 Bird 0.75 grains 2.01 mm (0.080")
#10 Pest 0.51 grains 1.80 mm (0.070")
#11 Pest 0.32 grains 1.50 mm (0.060")
#12 Pest 0.19 grains
/ 380 shot shell
Had an idea the other day and had a few min to see how it would work.
I took a spare Lee powder through die I had and removed the flare portion from the inside and replaced it with an insert I machined to swage the 380 case down like my 45 ACP die does.
Much faster and the crimp looks a bit better.
/ 380 shot shell #28
i tried to turn a fireball case yesterday and tore it. i just need a better fit on the mandrel.
/ 380 shot shell #29
CCI does offer a 38/357 shotshell.
As for snakes, these rounds should be considered "lucky" shots. The shot content/spread makes a definite hit/kill a matter of luck. Yes, I've used the 38 shotshell on snakes but it often takes more than one round. The 44 round is MUCH more effective.
/ 380 shot shell
.221 fireball will be too thin to turn, the only reason a .223 works is because the web is so thick that low.
38/357 is a completely different round than the 380.
Speer sells capsules for the 38/357, 44 and 45 calibers but they are all for use in revolvers and would not work in this application, I know of no revolver chambered for .380 ACP.
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
208320 (A58375)
208320 (A58375)
10222 (A56858)
10222 (A56858)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
