Oil & Fuel 3720 fuel consumption
/ 3720 fuel consumption #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
Fellow Posters,
A quick word on fuel consumption by my new 3720. I now have had the opportunity to fill my tank twice (neither time was it empty, though). Keeping careful records, I have seen consistent fuel consumption on both fill ups. Last time I consumed 8.7 gallons for 13.2 hours work for an average of 0.67 gallons per hour. This was mostly mowing and I kept the RPM's at 2000-2550 most of the time for PTO work. My other hourly average was 0.72 gallons per hour. By contrast my previous 4310, on its last tank before trading, with 46 hours on it, did 10.2 hours work on exactly 7.0 gallons fuel, for an average of 0.69 gallons per hour. So far, the difference has been negligible in fuel consumption, but I never did PTO work with my 4310 before trading it, thusly I did not rev it the same. My opinion is that the 3720, after broken in better, will use a small amount less fuel than the 4310 did. By contrast, my father's 335-- 20 hp-- JD garden tractor used 3.8 gallons of fuel in 1.6 hours of mowing use last time, for an average of 2.38 gallons per hour. It weighes only slightly more than one of my loaded rear tires!!! Just shows how fuel efficient these machines can be.
John M
/ 3720 fuel consumption #2
I'm on pace with that. I filled up at 16.2 hrs and added 8.5 gallons from the low fuel light. I now have 28+ hrs doing some loader work, and about 4 hrs chipping and am not close to the low fuel light yet. I was kinda thinking around a half gallon /hr so your post reassures me.
I'd like to see the low fuel warning come on at about 10 gallons consumed personally. A 3.5 gallon reserve should be plenty.
/ 3720 fuel consumption #3
Guess I'll have to see how long it's lasting in our 4120. Seems like I use more fuel while mowing and if it's in 4x4. Mainly I would guess due to the engine being at PTO speed constantly and working on slopes. Seems to last quite awhile though (using 72" rear finish mower). The 14.5 gallon tank sure helps too /forums/images/graemlins/smile.gif I guess I can get by a whole day with a tank of fuel if I'm mowing most of the day or doing other work that puts a load on the engine.
/ 3720 fuel consumption #4
15.4 hours on 8.1 gallons or .526 gallons per hour
4.5 hrs of chipping, the rest was loader work cleaning horse pasture for friends and loading rocks and junk from out old barn foundation. Fair amount of "loafing" using it to pull trees in the proper direction when felling them etc.
We'll see what happens when I put the power rake behind it and start making it work a little more...
/ 3720 fuel consumption #5
On my 4310, I have used as much as 1 gal/hour while heavy mowing keeping the governor maxed out.
213097 (A64276)
213097 (A64276)
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
PORTA POTTY (A67714)
2020 DRAGON ESP 150BBL ALUMINUM (A67714)
2020 DRAGON ESP...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
