3720 died
/ 3720 died #1
Deerescaper
North Dakota
3720 John Deere
My tractor died today just like the battery disconnected. I have power to the lights and to the starter terminal from the battery. No connection to the ignition switch. Does anyone know if there is a fuse or fusible link that could have blown and where it would be located. Any help would be appreciated.
LG
/ 3720 died #2
There should be a fuse, I am not sure whch one it is
/ 3720 died #3
F1 (D) is a 30 amp fuse for the Key switch. There is also a relay you might check K2 (B) Start relay.
Sincerely, Dirt
/ 3720 died
Thanks guys!! It was the fuse you mentioned Dirt. Dealer had me tracing fusible link wire first in their diagnosos sequence. Been a busy snow winter here with over 60" since mid November so the old girl has to run on command. Over 1200 hours on the '06. First electrical issue I've had other than fuel sender. Once again thanks as this is a daily stop on the net to visit this forum for info.
LG
/ 3720 died #5
Glad you are up and running again.
Sincerely, Dirt
/ 3720 died #6
ditto, here on you getting it going based on Dirt's suggestions.
1998 CAT 938G WHEEL LOADER (A67714)
1998 CAT 938G...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A67714)
TIRE RACK WITH...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2018 Komatsu D51PXi-24 Crawler Tractor Dozer (A66734)
2018 Komatsu...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
