3720 cruise control button
/ 3720 cruise control button #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
Well, since the tractor has 930 some hours, I can see how dirt and small pieces of hay got under the button. But how do you clean it out? :confused: I stuck a screw driver into the holes under the fender to find holes that only go into a hollow space. So there are no screws. I suspect that the button just snaps in there but I dont want to break anything. How do you clean it out to work again?
/ 3720 cruise control button #2
I am sure you can take he switch apart but I think that some compressed air would work. Maybe some contact cleaner and compressed air. The top piece snaps on and I believe most of the switch is sealed.
/ 3720 cruise control button #3
The buttons are inserted from the top but lock into the bottom. Take the panel off to access them. Pics are from when I installed my switched light relay and seperate on/offs for the front/rear lights I added. Once I got the part number I changed out the switch in pic3 to the ones in pic4.
CATERPILLAR WHEEL LOADER (A65053)
CATERPILLAR WHEEL...
John Deere 2700 6 Bottom Plow (A64911)
John Deere 2700 6...
CID FDM60-S 60in. Hydraulic Forestry Disk Mulcher Skid Steer Attachment (A66734)
CID FDM60-S 60in...
2013 HILL COUNTRY (A67714)
2013 HILL COUNTRY...
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
John Deere 757 (A64912)
John Deere 757...
