3720 Cab: Loader popped, Broken Window Panel
/ 3720 Cab: Loader popped, Broken Window Panel #21
Deere came up today and with the help of couple prybars and and a highlift jack we got the loader off the mounts, reversed the mounts and reinstalled. Loader moves on and off without issue now.:thumbsup: Even the tech said it would be helpful if Deere would mark the mounts R or L as they do that on a lot of other side specific parts for other tractors and equipment.
Thanks to this thread I have avoided potential damage and/or injury.
Thanks guys!!!:drink:
Actually the techs should know which way the mounts should be mounted. They also should be trying to take them on and off, at least once before they deliver to the Customer too. On the 300/300x/300cx manual it shows what they look like and some good shots of what they look like form the side view. So I dunno, seems that they need to take a few minutes like my dealer did and try out a few things - saves them having to deliver, pick up and then deliver again. They can catch it at their shop, fix it and then deliver only once. The manual shows which way the notch is positioned - towards the front of the unit.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
PAN (A62613)
PAN (A62613)
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
