3720 Cab: Loader popped, Broken Window Panel
/ 3720 Cab: Loader popped, Broken Window Panel #1
JasonMac
NH
John Deere 3720 Cab Tractor
I never take off my loader, I have no reason to. All of my bolts were tight, and the mast adjustment was tight. So I was digging into a pile of gravel, and the load I was biting into was a little to the right side of the bucket......... Then BAMMMMM!!!!! My Right foot window popped and smashed... come to find out my loader mast popped off its bracket!!! I had a **** of a time getting the loader back on the right way afterwards.. but I got it..... has this ever happened to anybody else before?
So the tractor is going in for: New Window, Brakes Sticking and not releasing, and 3pt hitch lever sensor......(if i move the lever a quarter inch forward load goes all the way down, if I move it back a quarter inch it goes all the way up).... not much room for a middle lever position....
I also want them to check my refrigerant for my A/C, doesn't seem to be pumping out as much as it once did.....(oh and filters are new)...
getting frustrated~~
/ 3720 Cab: Loader popped, Broken Window Panel #2
Sounds like the FEL may have had tight bolts/nuts, but I'm willing to bet it was not adjusted properly when it was first installed on the tractor. That is a dealer's job, and sometimes it is relagated to someone who doesn't bother to do the final adjustments.
Believe me, I use to do that setup, and it was a step that could easily be skipped, and few would be the wiser. Sometimes they come from the factory right on the money, but not always.
Adjusted right, it will NOT pop off unless there is damage to the front weight bracket where it attaches to the tractor.
Well, I really don't know what had happened.... I've been saying for quite some time that my loader seemed like it was out of adjustment of sorts.... One way I could tell is the center nut on the metal hydraulic hose guard didn't seem like it was centered to the rest of the tractor... (looking at the front grill, the center nut on the cross tube on the loader seems like it was about 3"-4" to the left of the center of the grill on the tractor..... But, they told me it was okay.. I still thought it wasn't really right, like something was tweaked...
Then as I was trying to get the loader back on it's base after it popped off, I notice the right side mast bowed out quite a bit further than the left side mast.... (bowed out like it was 3"-4" to wide to sit on the horizontal posts that it attaches too.... So like I said, it took me about a half hour to get the loader back on the tractor..... I had to attach the right side first, and kind of steer myself under the left, and hope I don't blow out the other window....
So if the loader is tweaked... what is the remedy to straighten it? (I would think that we would have to loosen every frame bolt, straighten it out, then tighten it up again... seems logical)....... or is my frame bent? or the posts that the sit on bent? I really don't know?
/ 3720 Cab: Loader popped, Broken Window Panel #4
Wow...keep us updated on what happens.
Could the mounting posts have been installed backwards (Left to Right)? I seem to remember a couple threads a while back about that...
/ 3720 Cab: Loader popped, Broken Window Panel #5
I remember the posts regarding incorrect loader mounts -- loader was very loose and sloppy on the horizontal mount. Either the dealer or the factory (both really..) had messed up from the get-go.
Dealer made it right in the end!
Everything sounds like a similar situation here -- except the shattered cab window!! :eek:
Hopefully, the dealer will also handle this in a like manner.
Keep us posted.
AKfish
/ 3720 Cab: Loader popped, Broken Window Panel #6
I'm 99.9% sure they"re gonna tell you yout loader mounts were backwards. I had this happen with a full heaped load of stone at full height. And sure enough the mounts were on backwards. It's the only way the mast can come off.
Matt
/ 3720 Cab: Loader popped, Broken Window Panel #7
Great White
I think you may be right there.
Hope all comes out ok in the long (or short) run.
I'd take some pics of the mounts for a record before it goes in for work. Just to protect you from the "they were ok" so not our fault. In the meantime they get switched right.
/ 3720 Cab: Loader popped, Broken Window Panel #8
Gonna watch mine a bit closer now after reading this. When JD techs delivered my loader they installed the mounts and such, but after they left I went at a pile of snow and as soon as I lifted the load, the left loader mast would lift off the mount about 1/2-3/4". Called them back and they adjusted it but it still seems quite "sloppy" on the mounts.
Which way are the short 4-5" round bars on the mounts supposed to face? Toward front of tractor or toward the cab?
/ 3720 Cab: Loader popped, Broken Window Panel #9
Here is a copy of installation instructions.
  • loader frame install.pdf
/ 3720 Cab: Loader popped, Broken Window Panel #10
Thanks JD110... as I recall my mounts are on backwards. When they brought the loader up the manual was sooooo soaked with water that they couldn't peel the pages apart to see how to install the mounts. And now that the manual is dry the pics and words are all smudged and pretty much useless. I believe that the rods are pointed toward the cab, thus giving the "sloppy" movement of the loader. It has been too wet here to use the bucket so I the tractor just sits in the shop for the last month. Will be checking that out tomorrow!!!!!
Thanks again!!!
/ 3720 Cab: Loader popped, Broken Window Panel #12
I have had this problem since I bought the tractor a year ago. When I bought it I had to add the loader so the dealer installed it. Several times doing different things, either one or both masts would pop up about an inch. What a pain to get them back down right. So after reading this post I got to thinking, could mine be on wrong. So today I removed the loader for the first time, and sure as I am typing here, they are on the wrong sides. So to recap, the dealer failed to install the masts correctly, didn't top off the hydraulic fluid after the load install and the quick release knobs were so loose the loader rattled around.....sheesh. So down to the shop now and switch the masts around.
/ 3720 Cab: Loader popped, Broken Window Panel #13
Sure enuff the mounts are on backwards:mad::mad: I tried to remove loader yesterday and can't even get it off the tractor!! Raise the front, release locks, move loader forward, etc.. etc... only problem is... is when the loader is at full "stretched out" position it just raises the loader striat up and not allow the masts to disconect from the mounts:confused:
I stuck a screwdriver under the masts to feel where the locator rods are and yep they are on wrong. Gonna call dealer first thing in the morning to get them up here to fix yet another screw up on their part:(
/ 3720 Cab: Loader popped, Broken Window Panel #14
WOW, this rears it ugly head yet once again. This was a hot topic a few years ago, but I thought they (JD) where clearly marking the parts now to keep it from happening anymore.
/ 3720 Cab: Loader popped, Broken Window Panel #15
I looked at the masts when I had them off, there are not markings on them. One would think that JD would mark them Left and Right, or at least put an arrow on the end indicating FRONT of tractor. I will say, the loader has much less slack in the masts now and I tried to get the masts to pop up and was unable.
/ 3720 Cab: Loader popped, Broken Window Panel #16
I think I may have the same problem, I will be taking the loader off for the first time today to find out for sure. The first time I was using it to move dirt the loader was coming a couple inches off of the masts and it scared the crap out of me when I saw it. Dealer told me to adjust the cap screws back against the mast pad finger tight and then snug them back with a wrench. That worked but it still seemed like a slight gap would open with a load on. I'm really anxious to see if the masts are installed correctly.
/ 3720 Cab: Loader popped, Broken Window Panel #17
Guess what, backwards. I think I may have made a purchase from the wrong dealer. This is about number 4 or 5 things I have found incorrect. Without this website I never would have known to check. Though I would have found it when I tried to remove the FEL because it doesn't want to come off with them on backwards. I would not have know why just that it wouldn't come off. Time for a long discussion with the dealer. Probably get me no where I just hope that they didn't miss something major that I haven't found yet. Now I know why I am haveing trouble removing my 72d mmm.
/ 3720 Cab: Loader popped, Broken Window Panel #18
Geez, that's too bad. Not much good comes from not trusting the dealer.
Hope you get things worked out.
I am amazed that several operators appear to have the same problem.:confused:
/ 3720 Cab: Loader popped, Broken Window Panel #19
Deere came up today and with the help of couple prybars and and a highlift jack we got the loader off the mounts, reversed the mounts and reinstalled. Loader moves on and off without issue now.:thumbsup: Even the tech said it would be helpful if Deere would mark the mounts R or L as they do that on a lot of other side specific parts for other tractors and equipment.
Thanks to this thread I have avoided potential damage and/or injury.
Thanks guys!!!:drink:
/ 3720 Cab: Loader popped, Broken Window Panel #20
There have been some references to the "masts" being on wrong, but I assume they really mean the mounts. Those are the stubs that the loader attaches to on each side.
I think of the mast as being the part of the FEL that attaches to the mount.
