3710 clutch replacement
/ 3710 clutch replacement #1
niffer91
powertrac 2425
My 3710 has only 1000 hrs and the clutch went on it. I've been quoted $2,500 plus labor to replace the clutch and I don't think it's worth that investment. Any suggestions on repair or perhaps selling it for tractors parts? Tractor is in great shape.
/ 3710 clutch replacement #2
That's a good tractor you have there. A 3710 in good cond., with 4wd and HST, is on the market for $13,500 on one of the online sites right now. That might be high, and I don't know what yours would bring, but maybe you shouldn't be so quick to assume it's not worth very much. If yours is a gear drive, 2wd, maybe it won't be so pricey, but Kubota's in any kind of decent condition hold their value pretty well.
/ 3710 clutch replacement #3
hi new member here.a possible problem may be the clutch fork shaft is frozen up.Check your operators manual for possible grease points.Mine was frozen up,discovered problem after I split my tractor which did not have zirks for the shaft but I do now.Good luck
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A64556)
2017 Ford F-450...
2022 GEHL RT215 SKID STEER (A65053)
2022 GEHL RT215...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
(UNUSED) GOODYEAR 28L-26 TIRE (A64278)
(UNUSED) GOODYEAR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
