366 Frame Mounted blade
/ 366 Frame Mounted blade #1
Nuru
Elite Member
Hey all, as some of you know I am close to pulling the trigger on getting a 3320 Cab tractor. In discussing with some of the folks on the forum, I found out the 366 Frame Mounted Blade and the MMM for this unit are not really compatible - (you have to take the MMM off and then put the frame mounts on then the blade and vice versa - not a quick operation). This puts me in a position to choose between a MMM and a boom blade (I have this now and have not mastered it yet), or an RFM and the Frame Mounted blade.
I am leaning towards the frame mounted blade and RFM, however i have never used an RFM, and I do like the MMM. However, I also like the Frame mounted blade from my days using one on my 4100. So I may take the plunge on the Frame mounted blade and get a 3rd party RFM (used or new).
However before I do that, I was hoping for some recommendatons either way from anyone!:eek:
/ 366 Frame Mounted blade #2
Changing the brackets will take you an hour tops...so that's 2 hours per year-well worth it IMHO. If you have wide open places to mow the a RFM is great, but if you have a smaller space with trimming to do around trees and/or against fences then the RFM are a PITA-you just do not have the maneuverability that you do with a MMM.
Hmmm, maneuvers did not remembber to think of that, and you are right it would be only twice a year. I did have to switch between the brackets on my 4100, did not take so long, but I could use an hour or two per year of tractor bolt-turning. BTW do you know if one can have the loader brackets and the brackets and mounting hardware for the Frame mounted blade on the unit at the same time? I thought I heard that you also have to switch those off and on too?
/ 366 Frame Mounted blade #4
Dirtworks has done it, and I think it's a good idea-but the modification did involve welding...But I am pretty sure you can't leave the blade brackets on with the MMM because they hang down to low.If there was even a slight chance you would get a MMM in the future, making Dirts modification could haunt you...
Yeah, whe i looked at the 3720 Cab and the then saw Dirt's mod and boing my mind how what you are saying is true the Blade's bracket's hang too low. Seems if i go with the frasme blade, I will just remove the loader brackets and the MMM, then install the Blade. That is not gonna be too bad.
/ 366 Frame Mounted blade #6
It's not bad, I have helped my freind who has a 4400 change his over. It is only 8 bolts and some hardware up front to go between the FEL and the blade.
He just bought a used 72" MMM but does not have it mounted yet-so I cannot comment on that yet...
/ 366 Frame Mounted blade #7
Nuru, IF I am not mistaken you can not install the frame mounted blade brackets with the CAB tractor without modifying the cab mounts. The loader mounts (green) and the cab mounts (black). You will see if you look close what I am talking about. The frame mounted brackets will NOT go behind the cab mounts without taking out the 1/2 for the width of the frame mounts.If you put the blade mounts behind the cab mounts without modifying it throws the holes off that the cab bolts go thru to secure the cab to the cab mounts. Taking the 1/2 inch out lines everything back up correctly. Its not as simple as a non cab tractor where you would be just doing the modification to the loader bracket. Hope that makes sense. Unless you have someone with excellent welding skills or a fabrication shop that you trust with your new baby.......................well I wouldn't just trust anyone if you know what I mean.
I'm not sure yo can see it in the pic below, but the loader mounts are the green part. The loader mount bolts to the black cab mount. The cab mount bolts to the tractor and is the part that you have to cut out the 1/2 inch. To remove the cab mounts, first lift up the floor mat inside the cab and remove the cab mount bolts, then you have to unbolt the 4 bolts and then slightly jack up the cab. You can see I have a bottle jack and a 4x4 under the cab to support it. I removed both front cab mount bolts and then jacked the cab up just enough to remove the cab/loader mount. Once this is done you can slide out the cab mount and have it modified.
Your easiest solution is to get the 3pt front blade and then it is compatible with the MMM. I think the MMM is going to be the better mower if you do lots of closeup mowing. If you want to do the cab mount mod I'd be glad to help anyway I could and could even have my friend do the mod for a reasonable charge. He is a very compitent welder/machinest. So, everything will be dead on..Doing the cab mount mod is the harder of the two solutions and thats my problem. I've never done anything the easy way!
Sincerely, Dirt
Ok KennyD and thanks.
Sincerely, Dirt
dirt, thanks for the info. I have a question or two:
Regarding this sentence " Your easiest solution is to get the 3pt front blade and then it is compatible with the MMM. "
Are you saying after the mod, the 3PT Front blade is compatible with the MMM? I was thimking that it was not, but I have not been able to find online, any diagrams of the 366 Blade - Does anyone have access to this diagram? I was thinking the Blade mounts protrude too low to be on the tractor when the MMM is on the tractor. If they don't then that would be good.
I might take you up on the offer as I can ship the mounts to WV in a day or two with ground shipping.
Another thing that has come up. I am beig told the MMM will not work well with the SuperTurf tires. It does on my 4310, so I think they are speaking of a clearance issue with the SuperTurfs. I am looking at some wheel spaces to see if those would potentially alleviate the issue. Anyone else heard of this problem?:confused:
/ 366 Frame Mounted blade #11
Nuru, doing the mod I have will rule out the use of a MMM. Is the 366 front blade an old style frame mounted blade that uses similar brackets to my set up or is it a new style blade that uses or is compatible with the new front 3pt hitch. If it is an old style blade that you are adapting to your tractor with the same mod as mine then a MMM will not be compatible. Hope I don't have you confussed. What I am saying is the new style 3pt front hitch blade would be compatible with the MMM or the RFM. If you choose to do the cab/loader mount bracket mod, then you HAVE to use a RFM. Again easier to go with the new style front blade and pick whatever mower will work best for you. MMM or RFM. If there are issues with a MMM that can't be worked out with the style of tires you want, then doing the cab/loader mod might be worth the trouble.
Sincerely, Dirt
Sincerely, Dirt
Thanks Dirt, hmm, that is interesting as i will check up on that. As I think there is some issue even with the new system. But it may be simply that you cannot have the mower on the unit when you have the blade on the unit and i won't have to change the brackets.
Hey KennyD, do you know?
Well I went down (well up to), to the local dealer and discussed with serfvice about the Frame mounted front 3PT hitch blade, and it is compatible with the MMM. So all I would have to do is remove the blade and the hitch to put on the loader or run with just the MMM. So I guess I am gonna go with MMM and Loader, and get the front hitch mounted blade.
Seems the 366 blade is only 66" wide, so i think I might make or buy some extensions to get the blade covering at least 72"
/ 366 Frame Mounted blade #14
Nuru, not sure but there is a possiblity that the blade extensions Deere made for a model 74 may fit or be adapted to the 366 you are buying. I'll email you a pic if I have it saved somewhere on my PC.
Edit: Sorry, Nuru...................I can't seem to find the pics of the Deere blade with the extensions.
Sincerely, Dirt
/ 366 Frame Mounted blade #15
Glad you got an answer because I know nothing about the new front 3PH stlye hitch or blades. But I do there are extensions available (both sides and top) like DW said.
Sincerely, Dirt
thanks Dirt!
Thanks and no problem Kenny.
Well I went down (well up to), to the local dealer and discussed with service about the Frame mounted front 3PT hitch blade, and it is compatible with the MMM. So all I would have to do is remove the blade and the hitch to put on the loader or run with just the MMM. So I guess I am gonna go with MMM and Loader, and get the front hitch mounted blade.
Well I did get the 366 blade, and I have been investigating the Side extensions and found out the following:
There are two parts that one would need:
TY13028 Side Extensions - ~ $117
BM22127 Top Extensions - ~ $80
I called a few dealers and no one seemed to know what the dimensions are for these parts. Also everyone said these extensions are for light material only. Also based on what the dealers were seeing in their files, they indicated that the side extensions appear to be at least 1/3 as wide as the blade?
Seems like they might not be what I was looking for as I wanted to add some additional width but it needs to be as sturdy as the rest of the blade or close to it.
Has anyone out there added extensions to the 366 blade or the 74" blade? If so can you send pics or at least provide some impressions of how solid/stiff the extensions actually are?
B4 I go down the road of aftermarket extensions, I want to see if I can get by with these in wet snow?
/ 366 Frame Mounted blade #19
Nuru, in order to mount both the MMM and the front TPH, JD supplies an optional "Front 3-point hitch/mid-mount mower draft arms" kit, identified as Bundle LVB24810. This kit replaces the standard draft arms for the MMM with draft arms which do not interfere with the front hitch.
Good luck with the front blade.
Thanks, GreenWannabe, Yes; I ordered that kit and I will install the entire front hitch set when the kit arrives.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
2023 MAD JAX X40 ELECTRIC GOLF CART (A62130)
2023 MAD JAX X40...
MASSEY FERGUSON 4607M TRACTOR (A62130)
MASSEY FERGUSON...
2019 CATERPILLAR 289D SKID STEER (A62129)
2019 CATERPILLAR...
