3616 Shuttle
/ 3616 Shuttle #1
dinoedwards
kubota
Is it rue that a 2013 3616 has DOC not REGEN?
Plus the shuttle is true gear on gear with no clutch per say?
See one with 700hrs foe 12,500. thoughts?
/ 3616 Shuttle
Just talked to owner and says no regen on this unit made in Japan.
He was a dealer and says these are real good units.
Is it true the loader is mounted to the block or frame?Log into Facebook Check up video and pix.
/ 3616 Shuttle
/ 3616 Shuttle #4
I have a 3016 and so far it has done all I ask. It is a shuttle shift. There is a true clutch that needs to be engaged in order to change gears or shuttle back and forth between forward and reverse (just like a true manual transmission).
Sent from my SM-S711U using TractorByNet mobile app
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
HONDA generator (A64557)
HONDA generator...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
Kubota ZD221 48in...
