3616 Shuttle
/ 3616 Shuttle #1
dinoedwards
kubota
Is it rue that a 2013 3616 has DOC not REGEN?
Plus the shuttle is true gear on gear with no clutch per say?
See one with 700hrs foe 12,500. thoughts?
/ 3616 Shuttle
Just talked to owner and says no regen on this unit made in Japan.
He was a dealer and says these are real good units.
Is it true the loader is mounted to the block or frame?Log into Facebook Check up video and pix.
/ 3616 Shuttle
/ 3616 Shuttle #4
I have a 3016 and so far it has done all I ask. It is a shuttle shift. There is a true clutch that needs to be engaged in order to change gears or shuttle back and forth between forward and reverse (just like a true manual transmission).
Sent from my SM-S711U using TractorByNet mobile app
