3550 quality
/ 3550 quality #1
4tillingdirt
nc
N/A
I know everyone has their favorites, but I have been researching tractors in the 40ish HP range and I cannot make up my mind. I was wondering how many people on this forum have had issues with more recent 3550s?
Thanks
/ 3550 quality #2
Had my 3550 for nearly two years. So far my only issues are a burned out tail light and one of the rubber brake pads won't stay on the pedal. I did my own break in maintenance and getting the hydraulic screen out was a bit of a pain. Everything else has been good so far.
/ 3550 quality
So what made you go with Mahindra? I priced a 3550 and they are several thousand less than a New Holland.
/ 3550 quality #4
Depends on what NH your are comparing it to. The 3550 is a big heavy beast with large tires. I have a 2011 5035 [ thumb picture at left ] pre Tier IV final that is a fine tractor. The tractor is well laid out with a large open operator area. If I would knock anything on it, was that it could use more HP due to having to push around it's 8500 pounds, but it does OK. More HP, and it would stress the hydrostatic trans. The cabs on the 3550 are pretty nice compared to the 2555's, but both are just fine.
/ 3550 quality #5
I just recently Bought 3540 PST. 1 month ago. Only thing battery was apparently no good after 1 week of use. Called them and they brought a new battery out to my house and replaced it. I have cleared land and moved approximately 100 yrd. of red clay and top soil. Pushed up big huge pile of trees that I ripped out. It's a work horse of a Tractor. Mind you it's only a 40 hp. open cab. Have a 6' box blade and 6' dual wheel medium duty 90 hp. gear box w/ slip clutch rotary cutter.
/ 3550 quality
Has anybody noticed that parts, fit and finish are not as good as NH, JD, etc and are there areas on the tractor rusting faster than you would have thought? I also read this on another post - to reset the service hour count you have to use a spare fuse to short circuit the reset slot per the manual. Has anyone seen this in their manual?
/ 3550 quality #7
I agree with the whole fit & finish statement. I had the headliner out of my 2565 last weekend while I was installing a camera system & noticed a couple of wires that go to the front work lights was simply run through a rough drilled hole that had not even been deburred & there was no extra protection on the wires. Granted there should not be much if any movement on the wires in that location, but why would you take the chance on having to troubleshoot the problem, then remove 30-40 plastic expansion anchors, then drop the headliner just to fix a short that could have been prevented?
/ 3550 quality #8
Mahindra needs some top management who wear Doc Martins to kick a lot of the existing top managers in the butt or out. Just the Mahindra web site says it all.
/ 3550 quality
From my research a Mahindra 3550 is about 5 - 6K less than a NH Boomer, etc. I guess with all of the issues I have read about apparently they need to spend some more of that money they are saving people. I am leaning more towards a New Holland Boomer or a Massey 1700 series. One thing I like about the boomer is that it has larger front tires/wheels than the Massey. The one positive about Mahindra besides the price is that it doesn't have to go through a regen from a dealer told me, but I just wonder what other contraption they have come up with to pass emissions.
/ 3550 quality #10
Mahindra uses a catalytic converter like the New Holland Workmaster 50/60/70 series.
/ 3550 quality
So how do they pass when all the others using DPF and regen cycle.
/ 3550 quality #13
Mahindra and others are using a DOC ( diesel oxidation catalyst ) compared to a DPF ( diesel particulate filter). They both have positives and negatives. Both should be good for thousands of hours.
/ 3550 quality #14
Thanks
The few bugs that I have had with my 3550 have been worked out. All the fixes should be incorporated on new machines. I have not had any issues since the updates, I have around 650 hours.
I like mine for what I do. The extra weight, loader capacity, and tire size are worth it for what I do with the machine. If you are only mowing or driving fast on the road there may be better machines, but for material handling or heavy ground engagement work or rough terrain, I don't think the competition stacks up as well for my uses.
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2010 Chrysler Town and County Van (A61574)
2010 Chrysler Town...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
