3540 Hydraulic leak
/ 3540 Hydraulic leak #21
It's not always the 4X4 seal. The HST input shaft and housing can leak also into the clutch.
True, its not ALWAYS anything.... Lots of things on these tractors that can leak. But then we were talking about my particular leak weren't we.
/ 3540 Hydraulic leak #23
deleted
He did not split it. Start to finish it took him maybe 40 minutes max..
What year is your L3540? Also, do you have any info on the repair kit, like a part number? Thanks!
I believe my tractor is a 2007 model
Just got the invoice on this. it says (not sure if it is a Kubota part number sorry
Item: TD060-98002
Type: PA
Description: KU-Kit sleeve, GST
I see it says "GST" which is a Glideshift trans , Mine is not a Glideshift but a HST trans. Hope this helps., Oh the kit was $51.84
/ 3540 Hydraulic leak #26
In the event anyone is interested in seeing the items in this kit, it is mentioned in the part diagram for Grand L 30's (example L3130)
See FRONT AXLE/CHASSIS, F12001 PROPELLER SHAFT [EXCEPT HST TYPE]
Ballon number in drawing: 180.1
Title: KIT SLEEVE, GST - replaces #TD060-98000
Part Number: TD060-98002
Price: $40.94
1 to equal #TD060-98000
/ 3540 Hydraulic leak #27
I just took my L3540 in last week for a leak at the split pin. I've been aware of this issue for a couple of years now. Mine just started to leak about a month ago. I only have 375 hrs on mine and was getting ready to change the hydraulic fluid for my HST and noticed the drip from the split pin. Dealer called me today to tell me the leak is from the tranny side and the tractor will need to be split. 10 to 12 hrs of labor at $69/hr. I told them I expected it and to go ahead and replace any other seals in there while they had it open. They mentioned I already had the updated seal on the transmission which I found curious. Apparently the updated Kubota seal doesn't fix the problem?
Background - I bought this tractor used. I believe it's a 2007 year model so that's pretty close to the first year of the 3540. As you can see, I don't put too many hrs on the tractor, but I do like the machine for it's utility when I need it. I also don't run it in 4 wheel drive unnecessarily specifically to avoid any strain on the seals to lessen to possibility of a leak starting up. So much for that cautious approach.:confused: We'll see how this goes...
HP
/ 3540 Hydraulic leak #28
The drivetrain will spin as many times in 4wd as in 2wd. I could see less wear on bearings or gears, but not really on the seals from running unloaded.
HP
Sounds like the same issue on the same year tractor, maybe a second opinion is warrented?
/ 3540 Hydraulic leak #32
I would probably think the same, but this dealer's workshop isn't about to dive into my tractor to drive up their workload for shop income. They have plenty of valid work to do, to include new tractor sales prep. They move a lot of equipment. I'll relay exactly what they replaced on the invoice when I get it back. I want to make sure I'm correctly explaining what seal they are replacing. I'm just hoping this fix will last longer then the 375 hrs this one lasted.
HP
HP
I've got like 1100 or so hours on mine now, I bought it used with 320.
/ 3540 Hydraulic leak #34
On my 2012 there was an updated seal for the HST input shaft. The new seal was double lipped and the one I removed was a single lipped design. Also the seal housing has been updated to a heavier design. The price for the parts was relatively cheap.
/ 3540 Hydraulic leak #35
First post new to forum , has great info , I have a L3940HST with leak from plit pin , after reading hunt4570 post I thought I would try the kit that fixed his before doing a tractor split , hope the fix is that easy !
WELCOME to the forum Mike! Keep us posted on how this all works!
Nice speaking to you this morning!
/ 3540 Hydraulic leak #37
Thanks hunt4570 , kit should be in today , fingers crossed ! Lol thanks for info !
/ 3540 Hydraulic leak #38
My tractor is now repaired. I was about to change the HST hydraulic fluid and filters anyway so the timing worked out when they split the tractor and had to remove the fluid. Here's a copy of the invoice showing parts used. I already compared Hunt's seal kit number to my invoice, it's not on there.
I believe my leak was on the transmission side. When the service rep called me stating they had to split the tractor, he stated my tractor already had that updated seal. Hopefully, this will solve the problem for many thousands of hours into the future.
HP
My tractor is now repaired. I was about to change the HST hydraulic fluid and filters anyway so the timing worked out when they split the tractor and had to remove the fluid. Here's a copy of the invoice showing parts used. Hopefully, this will solve the problem for many thousands of hours into the future.
HP
Might I ask what the price tag on all that work was?
So Mike.. whats going on with your tractor?
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
Case HI DMI Ripper (A62613)
Case HI DMI Ripper...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2004 Chevy 2500 Pickup Truck (A66408)
2004 Chevy 2500...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
