3525 or 5525
/ 3525 or 5525 #1
Amwellls1
sw Pa
1957 MF to-35
I am looking to retire my ferguson to35, I am torn between these 2 tractors, the 35 has been plenty of tractor for what I need size wise. Is the 3525 enough or should I step up to the 5525. Any input or advice will be appreciated.
/ 3525 or 5525 #2
That is an individual decision depending mostly upon your own needs but, for what it is worth, I just made the same decision and went with the 5525. The reason is that the difference in price was less than 2K and, for that amount, there is a very large increase in PTO horsepower from 27 to 44, and you get 4 cylinders rather than 3. In the back of my mind also is the fact that I intend to square bale a hay field in the future. Anyway, best of luck with your decision.
/ 3525 or 5525 #3
I also recently made that comparison and went with the 5525. It's been too wet, snowy and icy to do much with it yet since I don't live on the land where the tractor is but I would go with the bigger 5525 if possible. Looking at both on the lot there is not much size difference if you are thinking about maneuvering around trees. However there is a substantial difference in HP and I liked the larger front tires for stability when using the loader. I replaced an old Ford 860 and can't wait to really break it in. Good luck.
DB
/ 3525 or 5525 #4
If the 5525 was available when I was buying, I probably would have went for it instead of the 3525 although I'm very happy with the 3525.
Since the 5525 is a 4 cylinder, I would assume it is quieter than the 3 cylinder. My neighbor's 4 cylinder Kubota is much quieter than my 3525. Anyone compare engine noise between the two?
/ 3525 or 5525
Thanks all, I am leaning toward the 5525, the problem is my dealer does not have one right now and will have to get it shipped in. He has the 3525 on the lot. I am just having a hard time buying sight unseen, I am concerned about the physical size difference between the two. Is there that much difference in height and width?
/ 3525 or 5525
LAWALLSTRACTOR said:
Check the dimensions in the flyer.
I did that, but there is no reference on height or any indication of where the dimensions start and stop from. The dealer was not comfortable with the dimensions in the book for that reason. Also there is a conflict between the width on the web site as opposed to the flyer, from memory is was about 9".
/ 3525 or 5525 #8
i can't speak for the 5525, but the 3525 is a **** of a tractor for the money.
very good power, lifting and otherwise - for it's size.
but as most folks say - better to have too much power than not enough.
if you are in the middle on these two - go bigger.
but IF the 3525 will do all your forseable future chores - then maybe it's the right one.
good luck -
J
/ 3525 or 5525 #9
What kind of work will you be doing with the tractor? I'm not one to always say bigger is better without knowing what the tractor will be used for. Sure it may only be 2K dollars more, but 2K$ will buy you a lot of implements.
For some purchasers bigger is better but for others it isn't, just depends on the situation and what your future plans are (if you plan on acquiring more acreage, etc.)
/ 3525 or 5525 #10
Both the 3525 and the 5525 have direct injection engines, which, by nature, are noisier than indirect injection engines such as the Kubota's and even the Mitsu built Mahindra's.
I've heard both the 5525 and the 3525's, and they both sound similar. Just the nature of a direct injection engine. On the plus side, direct injection engines usually start easier in cold weather than do indirect injection engines, and are usually more fuel efficient as well.
/ 3525 or 5525 #11
Dave Siemens (Dave's Tractor) will be here at my place in about an hour to deliver my new 5525 with the ML250 FEL and a new 6-ft brush hog.
It's Spring and time to take advantage of the tractor sales. I got a great deal on the 5525/FEL combo and financing at 0% for 48 months. Traded in my 2005 Kubota B7510HST/LA302 FEL (21 hp engine) for the 5525. My monthly payments will actually drop by nearly $100.
Now I have the 5525/FEL and my 1964 MF-135 diesel project tractor (currently needing a new oil pump). Going to go haying later this year on my 10 acre spread. Need the 5525 power to handle the plowing, discing and, especially, baling. I'll use the 135 for the lighter chores. It's going to be nothing but tractor fun from now on.
/ 3525 or 5525
Well I bought the 5525 and it was delivered today, alot bigger then my 35 furgeson. Just for the hour or so that I ran it(played) seems to have alot of power. I have to get used to how high you sit on it though and can not wait to try the brush hog on it. Can not beat the 0% for 48. I will let everyone know my how she works out. Thanks for all the input
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
2017 Forest River Rockwood Freedom Camping S/A Trailer (A61574)
2017 Forest River...
213137 (A64276)
213137 (A64276)
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2015 Ford Mustang Convertible Coupe (A61574)
2015 Ford Mustang...
