3520 MFWD question:
/ 3520 MFWD question: #1
ACKBill
Bronze Member
Southern NH, USA
JD 3520
Hey all, I have a question for you. Where is the MFWD Speed Sensor located on a 3520? I get an intermittent Error code 06 which means loss of signal from the speed sensor. I have a hunch that, because it's intermittent, it might be a loose connection. I would like to start at the sensor and work my way back to the controller (cluster) and check all the wiring as I go but I can't seem to find a diagram showing the location of the sensor. Any help would be appreciated.
BILL
/ 3520 MFWD question: #3
Sorry, all I can recommend is that you try THIS LINK.
On edit: fix grammer. :)
/ 3520 MFWD question: #4
I think it is on the left side of the tranie and about 6" away from the drain plug,up and back a bit.
minimax
Minimax:
Thanks! I'll take a look tomorrow afternoon and see what I can see. I'll let you know.
Thanks again'
BILL
/ 3520 MFWD question: #6
Look at it agian to day and it is on the rights don't know why I was thinking left side???
minimax
Minimax:
I checked today (it finally stopped raining!) and you were right. On the right, just above and in front of the PTO shaft. Sure enough, the plug was loose, looks like it might not have been plugged in completely at the factory/dealer and then it got pulled loose while I was working. Cleaned it up, sprayed it with some WD-40 to make sure it was dry, plugged it back in and no more problem.
Thanks for the help!
BILL
YALE FORKLIFT (A63291)
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
MF GC2300 fel replaced
2015 Isuzu NPR 16ft. Box Truck (A61573)
2015 Isuzu NPR...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
